Pier and beam issues framing and floor deck showing.
Designer100
Does anyone know why my pier and beam foundation floor joists and beams disappear when I try to do perpective and I have to back out of it? Open old one! I custom drawn floor joist and pads and 1 concrete block on each pad then drew beams and floor joists. I keep trying to pull siding down over to cover the beams and floor joists and then they all disappear. I need the floor decking to appear on a section over floor joist to with deck up level with entry and grass under home.
I did this project in Chief x11. I would appreciate any help in this apartment.
Thanks
Newell Cheatheam
Katy,Tx. 77450
newell.cheatheam@gmail.com
713.385.3622.
Apartment_Plan.plan
I opened your file in X12 and pulled the siding down as per your post.
Here is the result.
So maybe this is an X11 glitch, or maybe try one of the following.
1) Restart your system and try again
2) Reinstall X11 and try again
3) Install X12 (I really like it)
Hope one of these works for you
Thank you Mark#D,
Do you or someone else know how to bring the front porch deck up by Entry door with 4 steps to ground? Also put grass under apartment.
Newell Cheatheam
www.newellsdesigns.com
This is in X11. I have x12 but this small apt and main house in x11
newell@newellcheatheam.com
281.392.3034
Apartment_Plan.plan
