recessed wall cabinet bottom for light rail
nancyscial
On 2/13/2020 at 4:12 PM, nancyscial said:
I am trying to show a recessed wall cabinet bottom for inserting a light strip.
I need to be able to show the bottom of the cabinet recessed up by 1 1/2" with the sides still down. The doors should cover the recess also.
Nowadays I use 3/4" which is easy in CA, more than that gets tricky and exactly what it looks like depends on framed or frameless (and if frameless check with the maker to make sure you get what you want) Plan attached.
Down and dirty method....
But you then need to place you own Doors as Chief won't drop to the bottom of the Valance molding but once the door is placed in plan from the libary and copied it isn't too bad.
Likewise for the Handle/knob.
Actually If you remove the Bottom seperation the Door will come all the way down , you can then use one of the Shelves set at 1 1/2" from the bottom as the bottom of the cabinet and the molding will fill the gap , see the attached wall cabinet for settings.
MHD 1.5 inch Recessed Bottom Wall Cabinet.calibz
