DzinEye Posted February 13, 2020 Share Posted February 13, 2020 I remember reading it a few times over the course of the last month, but my searches are fruitless now that I need it. ;( Link to comment Share on other sites More sharing options...
parkwest Posted February 13, 2020 Share Posted February 13, 2020 I don't remember the secret for X11 but X12 allows you to open multiple layouts. 1 Link to comment Share on other sites More sharing options...
DzinEye Posted February 13, 2020 Author Share Posted February 13, 2020 14 minutes ago, parkwest said: I don't remember the secret for X11 but X12 allows you to open multiple layouts. Thanks... ya I don't have access to X12 yet, I'm on monthly SSA. Link to comment Share on other sites More sharing options...
parkwest Posted February 13, 2020 Share Posted February 13, 2020 27 minutes ago, DzinEye said: Thanks... ya I don't have access to X12 yet, I'm on monthly SSA. Can you ask Chief if you can pay a month ahead so you can get X12? Link to comment Share on other sites More sharing options...
KenL-sdd Posted February 13, 2020 Share Posted February 13, 2020 Hold the control key down and quickly double click on chief to open. Sometimes this needs to be done a few times to work. 1 Link to comment Share on other sites More sharing options...
DzinEye Posted February 13, 2020 Author Share Posted February 13, 2020 2 minutes ago, KenL-sdd said: Hold the control key down and quickly double click on chief to open. Sometimes this needs to be done a few times to work. Thanks! Okay, so it sounds like I'm opening a whole new instance of Chief then, not just opening another layout tab. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 13, 2020 Share Posted February 13, 2020 There is the normal secret: Holding down the Control key and opening a second instance of Chief. I usually did this by right clicking on Chief in the task bar, holding down the Control key, and then left clicking on Chief Architect Premier X11. Give it a moment to open the second instance before letting go of the control key. As Ken said, it can take a few tries; however, the only reason for this though in my experience is that people don't give it enough time. Then there is the super secret method (always worked fine for me, but only do this at your own risk because the program wasn't designed with this in mind): Trick Chief into opening 2 layouts by using a non-existent font. Long story short, Chief loads layouts into the program but doesn't actually fully open them when there's a missing font, so you can use this behavior to trick Chief into pre-loading multiple layouts and then opening them both. Here's how: Place the following CAD block off to the side in your desired layouts. It won't hurt anything, it just uses a font that you likely don't have on your system... Multilayoutfont block.calibz Save your layouts. Close Chief. It's very important that Chief be closed before trying to open both layouts. From File Explorer, multiple select both layouts, right click, and Open Give Chief a little time to load both layouts before clicking on anything in the Replace Fonts dialog. You'll know Chief has loaded both layouts when you have 2 Replace Fonts dialogs (which you can see by dragging one off to the side). Again, only do that last one at your own risk. To date it's worked just fine for me, but Chief wasn't designed to do it and as such, and it may cause you problems when attempting to send to layout, switch pages, re-link files, etc. because of the fact Chief was only designed to deal with one layout at a time. For simple copy paste operations, it seems to work without a hitch though (other than the fact switching layout pages changes the page in both layouts simultaneously). In fact, you can even send to layout, but Chief can only send to one of them... ...of course in X12 its designed to work with multiple layouts, and it works great. 1 1 1 Link to comment Share on other sites More sharing options...
DzinEye Posted February 13, 2020 Author Share Posted February 13, 2020 18 minutes ago, Alaskan_Son said: Then there is the super secret method Very interesting... thanks.. Well I'm going to go ahead and try the standard method, and if that doesn't work I'll give the super-secret method a go. Link to comment Share on other sites More sharing options...
DzinEye Posted February 13, 2020 Author Share Posted February 13, 2020 23 minutes ago, Alaskan_Son said: Give it a moment to open the second instance before letting go of the control key. As Ken said, it can take a few tries. The only reason for this though in my experience is that people don't give it enough time. Thanks for the tip!... keeping the ctrl key down is definitely the secret to this secret. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 14, 2020 Share Posted February 14, 2020 7 hours ago, Alaskan_Son said: Holding down the Control key and opening a second instance of Chief You can also disable the second instance behavoiur ( at your own risk) in the Chief .ini file. ( if you can't find it , then don't use this method.... and make a backup of the .ini file 1st if you do.) 1 Link to comment Share on other sites More sharing options...
