KellySantaRosa
Is it possible to import models from Sketch up?
Is it possible to import models from Sketch up?  I feel like I keep reading threads where people are mentioning it, but don't see anything on how it is done?  I would like to import a Bamboo plant.
Thanks,
Kelly
Yes there is no problem. Just download the SKP file to a folder and then in CA use the file import 3D Symbol and select the SKP you down loaded.
You want to Import -- File>Import
5 hours ago, KellySantaRosa said:
Thanks!
Easiest way is to download to desktop, then drag into open plan.
Add to library if desired.
The SKP VERSION (year) is important though , Chief usually is able to import the .skp from 1 year behind the Chief Version Release year  ie for X11 in 2019, the .skp will need to be the 2018 version.
    27825
    ChiefDallas
    ChiefDallas
