capitaldesigns Posted January 30, 2020 Share Posted January 30, 2020 I am working on a hillside project where there are existing retaining walls. One of the retaining walls steps down with the grade. It starts off at 8' and drops down to 4' high. The retaining wall drop down 8" every 4'. I tried both the retaining wall and terrain wall. Using the retaining wall I do see where I can control the height of the wall. It looks line the grade behind the wall controls the wall height. Using the terrain wall I can control the wall height of the entire length of the wall. I can not break the wall into 4' long sections where I can give each wall segment its on wall height. Any suggestions on how to draw a retaining wall that drop down 8" every 4'. Thank You, Mike Link to comment Share on other sites More sharing options...
rgardner Posted January 30, 2020 Share Posted January 30, 2020 Foundation wall manually built and adjusted in elevation view Link to comment Share on other sites More sharing options...
glennw Posted January 30, 2020 Share Posted January 30, 2020 Don't use a retaining wall - use a Terrain Break and then use an ordinary wall. Edit the wall heights by breaking it along the top and then dragging in elevation view. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 30, 2020 Share Posted January 30, 2020 29 minutes ago, rgardner said: Foundation wall manually built and adjusted in elevation view this is what I normally do and then add a Terrain Break on the wall (closer to high side usually not centered) and elevation data/regions either side of the wall. M. Link to comment Share on other sites More sharing options...
