IggySwartz Posted January 29, 2020 Share Posted January 29, 2020 Textures are not rendering properly in standard or physically based techniques; they are showing texture but seem to have a solid over-color. This just came out of nowhere! How do I correct this? I use X11 Premiere. Thanks. Texture Problem 1-29-2020 comp.pdf Link to comment Share on other sites More sharing options...
IggySwartz Posted January 29, 2020 Author Share Posted January 29, 2020 Thanks, I will correct my signature. I did provide that info, however. Link to comment Share on other sites More sharing options...
IggySwartz Posted January 29, 2020 Author Share Posted January 29, 2020 I'll check the video card but it is fairly decent: 2047MB NVIDIA GeForce GTX 1060 6GB Link to comment Share on other sites More sharing options...
IggySwartz Posted January 29, 2020 Author Share Posted January 29, 2020 Driver is latest available version and is working. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 29, 2020 Share Posted January 29, 2020 If the texture shows correctly in the texture preview window when selecting it from the library then there is nothing wrong with your video card. That preview window is just a view generated based on the floor camera settings. The problem is likely in your plan or a setting. Post the plan and you will likely have your answer in 5 or 10 minutes. Link to comment Share on other sites More sharing options...
IggySwartz Posted January 29, 2020 Author Share Posted January 29, 2020 The texture does show correctly in the thumbnail preview. I am posting a sample plan file. Texture Problem.plan Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 29, 2020 Share Posted January 29, 2020 I have the same result as Eric. Does the plan you sent not look the same on your system? Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 29, 2020 Share Posted January 29, 2020 Are you sure you don't have textures toggled "off". Link to comment Share on other sites More sharing options...
IggySwartz Posted January 29, 2020 Author Share Posted January 29, 2020 No it does not. All of this started in the last few days. Link to comment Share on other sites More sharing options...
IggySwartz Posted January 30, 2020 Author Share Posted January 30, 2020 Where is the texture switch? Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 30, 2020 Share Posted January 30, 2020 3D, Camera View Options Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 30, 2020 Share Posted January 30, 2020 Here's what it looks like when I turn off textures. Link to comment Share on other sites More sharing options...
IggySwartz Posted January 30, 2020 Author Share Posted January 30, 2020 Thanks, Graham and Eric. That was the problem, however I must say someone must have hacked me because I did not do it! Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 30, 2020 Share Posted January 30, 2020 You are welcome. Always post the plan, we are not going to judge it, our interest is in solving the problem. Link to comment Share on other sites More sharing options...
IggySwartz Posted January 30, 2020 Author Share Posted January 30, 2020 I'm not worried about judgements at this point in my 78 YO life! How did you guys post the picture of the wall directly in your post? Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 30, 2020 Share Posted January 30, 2020 Just exported a jpg to file and then attached it to the post. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 30, 2020 Share Posted January 30, 2020 "File", "Export", "Export Picture". It will capture the displayed window. Link to comment Share on other sites More sharing options...
IggySwartz Posted January 30, 2020 Author Share Posted January 30, 2020 1 minute ago, solver said: Windows 10 has the Snipping Tool which lets you capture specific areas of the screen. Yes, I am aware. Link to comment Share on other sites More sharing options...
IggySwartz Posted January 30, 2020 Author Share Posted January 30, 2020 1 minute ago, TheKitchenAbode said: "File", "Export", "Export Picture". It will capture the displayed window. Am aware. Link to comment Share on other sites More sharing options...
glennw Posted January 30, 2020 Share Posted January 30, 2020 Tools>Screen Capture>Capture Screen. You can drag a rectangle to capture the area you want. This automatically saves to your -My Images folder in your Chief Data folder. Link to comment Share on other sites More sharing options...
IggySwartz Posted January 30, 2020 Author Share Posted January 30, 2020 12 hours ago, glennw said: Tools>Screen Capture>Capture Screen. You can drag a rectangle to capture the area you want. This automatically saves to your -My Images folder in your Chief Data folder. Thanks, I don't see the auto-save feature ... I have to manually save it ... ? Link to comment Share on other sites More sharing options...
Kbird1 Posted January 30, 2020 Share Posted January 30, 2020 34 minutes ago, IggySwartz said: Thanks, I don't see the auto-save feature ... I have to manually save it ... ? Its actually Chief Data Folder>Images>My Images (X12) but it only does it if the Screen Capture Tool is Setup to save an Image . It also adds it to your User Library for future use. If Screen Capture is setup to save a Picture it, it places and saves the Picture in the Plan on the CAD,Default Layer. M. Link to comment Share on other sites More sharing options...
IggySwartz Posted January 30, 2020 Author Share Posted January 30, 2020 Thanks, Mick. Link to comment Share on other sites More sharing options...
