jmsisco 11 Posted January 14, 2020 When I use an exterior fixture from the library like an HVAC compressor, that fixture is on the exterior fixtures layer but it's label is on the fixtures layer. Is there any way to change the label on the exterior fixtures so it displays on the exterior fixtures layer? Currently I am labeling it with text and creating an exterior fixture text layer. Share this post Link to post Share on other sites
rgardner 145 Posted January 14, 2020 22 minutes ago, jmsisco said: When I use an exterior fixture from the library like an HVAC compressor, that fixture is on the exterior fixtures layer but it's label is on the fixtures layer. Is there any way to change the label on the exterior fixtures so it displays on the exterior fixtures layer? Currently I am labeling it with text and creating an exterior fixture text layer. Select the item, open the DBX on the Layer or Line-style tab change the layer to the one you want it on. If you don't have a specific layer try pressing define, copying the current layer naming it and setting it how you want it to appear then you will be able to turn on and off the layer. There are some great videos on using layers in the KB. Share this post Link to post Share on other sites
robdyck 460 Posted January 15, 2020 19 hours ago, jmsisco said: When I use an exterior fixture from the library like an HVAC compressor, that fixture is on the exterior fixtures layer but it's label is on the fixtures layer. Is there any way to change the label on the exterior fixtures so it displays on the exterior fixtures layer? Currently I am labeling it with text and creating an exterior fixture text layer. As far as I know, currently we are unable to specify layers for labels. Share this post Link to post Share on other sites
Alaskan_Son 2458 Posted January 15, 2020 1 hour ago, robdyck said: As far as I know, currently we are unable to specify layers for labels. This is correct. We can however use custom macros to suppress labels in any given layer set AND we can also use the reference display in sneaky ways to change label display on an object by object basis. Share this post Link to post Share on other sites
robdyck 460 Posted January 15, 2020 Just now, Alaskan_Son said: This is correct. We can however use custom macros to suppress labels in any given layer set AND we can also use the reference display in sneaky ways to change label display on an object by object basis. An idiot like myself is just gonna type what I need! For example, mechanical room equipment labels, I just typed them out and made a block of the text and saved to my library of text items. Why...Because I don't want every other fixture on a basement plan to have its label on. Sure it doesn't use the program's ultimate capabilities, but it's dead simple. Each user needs to decide what works for them, but it seems like label layer capability would be a welcome addition to the feature list. Share this post Link to post Share on other sites
Alaskan_Son 2458 Posted January 15, 2020 17 minutes ago, robdyck said: it seems like label layer capability would be a welcome addition to the feature list. Yup. mos def. Been suggested quite a few times too. Share this post Link to post Share on other sites
jmsisco 11 Posted January 15, 2020 I'm going to stick with they way I'm doing it. Maybe Chief will add that feature in the future. Robdyck, Michael, Thanks for the input ! Share this post Link to post Share on other sites
SteveByars 6 Posted September 6, 2020 I found a workaround. You can change the label layer by changing the Symbol Category. Select the object, Select 'Convert to Symbol', and change the 'Symbol Category' to a category that your aren't already using. Geometric shapes and Sprinklers are my go tos. Share this post Link to post Share on other sites
