chomper Posted January 12, 2020 Share Posted January 12, 2020 I'm having no end of grief trying to create an indoor pool. I can make an outdoor one to my hearts content, however when I replicate the process in the "pool room", it won't work at all. Is there a method I'm not aware of to make an indoor pool? Using Chief X10 Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 12, 2020 Share Posted January 12, 2020 The attached ray trace was created in X8 for a client who has not, to date upgraded. How I created this pool room: 1. Created the structure 2.Added the windows 3.Drew the outline of the pool using room divider walls 4. In the resulting "Room Specification Dialog" I programmed the "room" to be open below 4. I then added the pool symbol and located it in the created "room" DJP 1 3 Link to comment Share on other sites More sharing options...
mtldesigns Posted January 12, 2020 Share Posted January 12, 2020 Love the back drop David. 8 months out of the year probably snow covered or too cold to have outdoor pool. I did the same thing as David mentions, created a room then used divider walls and opened below. Square or rectangular pools are easier for a inside room.. you can do plines too.. just more a PITA. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 12, 2020 Share Posted January 12, 2020 There are a lot of possible methods depending on the structural details of the room. Don’t forget about the Hole In Floor Platform tool though. Link to comment Share on other sites More sharing options...
chomper Posted January 13, 2020 Author Share Posted January 13, 2020 My god David, that is some epic design work! Your method may have done the trick, it looks like it's working. Wait, what's the pool symbol? Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 13, 2020 Share Posted January 13, 2020 The pool I merely got from my Library Browser as a symbol, take a look in yours. DJP Link to comment Share on other sites More sharing options...
Evolution Posted January 13, 2020 Share Posted January 13, 2020 6 hours ago, chomper said: My god David, that is some epic design work! Your method may have done the trick, it looks like it's working. Wait, what's the pool symbol? If you don' t have the pool symbol in your library files, you can probably find something in the 3D on line warehouse. Link to comment Share on other sites More sharing options...
SarahWestphall Posted March 13, 2020 Share Posted March 13, 2020 2 Advanced issues found ▲ 1 On 1/12/2020 at 2:02 PM, DavidJPotter said: The attached ray trace was created in X8 for a client who has not, to date upgraded. How I created this pool room: 1. Created the structure 2.Added the windows 3.Drew the outline of the pool using room divider walls 4. In the resulting "Room Specification Dialog" I programmed the "room" to be open below 4. I then added the pool symbol and located it in the created "room" DJP Hello, I've tried following these steps several times, I keep getting stuck once I change the room type into open below.... it pretty much does exactly that - opens the ground below and shows the backdrop in 3d view. I've tried placing a slab, however, this is what I get (snapshot attached). And oh, I used the gingham pool texture on the slab. What am I missing? I've tried Renerabbit's video method, but it didn't work very well either, I dont' think his method was created for an indoor pool, as the room walls keep attaching itself to the existing ceiling no matter how much I try to edit the specs. Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 13, 2020 Share Posted March 13, 2020 In an elevation camera, measure how low the pool symbol is relative to the floor level of the pool room. Then select the pool symbol using "Transform-Replicate - Move" and move it up in the "Z" axis the value you measured it needs to be. In the Pool symbol, change the "bottom relative to" box to "Absolute" so it stays put after the move. DJP Link to comment Share on other sites More sharing options...
SarahWestphall Posted March 13, 2020 Share Posted March 13, 2020 I'll try that thanks. Link to comment Share on other sites More sharing options...
