rockyshepheard
copying a window explodes casing
I have a window with casing switched on and a treatment above and a sill below.
I am attempting to copy this window from first floor to paste in place on second floor.
When I copy the width of the casing elongates several times the width of the window, while the height of the casing remains constant.
Is this human error or a CA glitch?
Thanks!
CASING EXPLODES.plan
Not an error on your part.  Just a weird bug.  Not sure it's worth discussing though because it's really a non-issue.  As soon as you move the redundant copy, the behavior goes away.  You might want to report to tech support though.
There were a number of these window artifacts in the Roof plane you posted the other day too Rocky , so I am not sure they "go away" on their own?
I haven't seen any example where the behavior sticks when the redundant copy is moved or deleted.
Can't say for sure , I didn't work on windows in that plan but they were definitely there as I thought WTH ! is that.... and deleted a number of them....
This is a bug that can happen when using edit area.  Somehow multiple copies of windows get dropped in during the use of edit area stretch command.  Not sure it that applies to this plan, just mentioning it.
    28307
    christiesternerz
    christiesternerz
