PacNWMike Posted December 14, 2019 Share Posted December 14, 2019 I would like to add a pony wall in a kitchen behind the peninsula cabinets. I would like to be able to specify the height typically 34½ to 46½ but it could be anything. Then I would cap it with wood trim or a bar top. I've tried creating a railing but that seems to be 42" and the cap is difficult to modify. The pony wall I create (see attached) is clipping the cabinet crown and valance even though ht is specified at 46½" and the added countertop does not show in the 3D or elev.. but shows in plan view. There must be a way to specify a wall by height. Thanks Mike X5 Link to comment Share on other sites More sharing options...
PacNWMike Posted December 14, 2019 Author Share Posted December 14, 2019 OK I see that I had the ht off floor wrong. Changed to 0. But still not seeing the countertop. Or a way to add trim specifically to the top of this wall only. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 14, 2019 Share Posted December 14, 2019 You should have a top rail option that can be edited. Link to comment Share on other sites More sharing options...
PacNWMike Posted December 14, 2019 Author Share Posted December 14, 2019 Thanks for the very fast response. Changing ht off floor fixed the clipping. Will try a railing... Link to comment Share on other sites More sharing options...
PacNWMike Posted December 14, 2019 Author Share Posted December 14, 2019 OK pony wall/railing w/cap only displays with the full camera or cross section elevation. Not with room camera nor wall elevation. (see attached) Now to try to fix the floor orientation. Rotate 90°. Thanks! Link to comment Share on other sites More sharing options...
rgardner Posted December 14, 2019 Share Posted December 14, 2019 On 12/14/2019 at 4:01 AM, PacNWMike said: OK pony wall/railing w/cap only displays with the full camera or cross section elevation. Not with room camera nor wall elevation. (see attached) Now to try to fix the floor orientation. Rotate 90°. Thanks! Expand use the material adjuster tool and adjust the texture 90deg. Link to comment Share on other sites More sharing options...
PacNWMike Posted December 14, 2019 Author Share Posted December 14, 2019 Done, thanks Link to comment Share on other sites More sharing options...
Kbird1 Posted December 14, 2019 Share Posted December 14, 2019 On 12/14/2019 at 4:01 AM, PacNWMike said: Not with room camera nor wall elevation. (see attached) Expand Nothing attached but this sounds like a Layer display issue in those two view types.... use your ALDO to determine the Layers in a full camera and then make sure they are on in Wall Elevation or a Room (Floor?) Camera too Wall Elevation cameras can also have railings and invisible walls set ti be "ignored" , so perhaps that is the cause? Link to comment Share on other sites More sharing options...
