Switched Outlet Symbol
lavorhaynie
This...
I think you might just want to note which of the receptacles is supposed to be the hot one.  Not sure there's any proper way to note top vs. bottom with a symbol.  Although I suppose you could add this to your legend and make left filled = top hot and right filled = bottom hot.  Just a thought.
13 hours ago, Alaskan_Son said:
This...
I created my own symbols where none exist in CA library then add it to my library. Works fine so far.
Because this type of outlet is usually under a kitchen sink, powering the garbage disposal, and because
the power cords you have to buy and attach to a garbage disposal often have one of those right angle
plugs with the cord coming out the bottom, it is best to have the switched half be on the bottom.
Otherwise the cord may occlude the bottom ( if the plug has to go in the top.)  You need the always on
half available for the DW
My 2 cents
