Electrical Problem
PrimeArch
Hello guys. I made a custom symbols and model for my electrical because CA dont have it.
I managed to make it but the problem is  they cannot stay side by side.. they will merge  like this
Btw the can stay side by side if each of em not the same height
How do i solve this? Please help
My solution is select object > Open Symbol
Uncheck all this in Option > Option ( previously I checked Switch + 220 Volt + Switched )
I just unchecked all those.
I dunno if this is the correct way to solve it, But it work for me.
8 hours ago, Kbird1 said:
It maybe the Switch Option, as I think Switches are hardcoded to merge (gang) together if touching ...Outlets may do the same thing? , but should be easy to test.
Yeah.. I spend 1 day to figure out the best way to make it not to merge each other. And I admit it is good to automatically merge to make it '2 gang or 3 gang' type. But the problem is it will merge switch and socket together when they both stay next to each other and at the same height. Btw thank you..
