Evolution
Barrel vault (ceiling plane) not working
I managed to get one Barrel vault modeled, but attempting the same on the other side of the room (mirror image) is not working.  I even tried copy reflect about that didn't work for ME either.  It might work for you, if it does please explain what made the difference.
I Checked the structure, on that side and it is the same as the side I was able to model.  I even copied the settings of the first (successful vault and pasted them in) unless something changed and I didn't catch it???
The Video I watched showed the same steps I followed and that worked fine on the first one, so why won't it work on the other? The space is the same identical area, only difference is coming into the barrel from the living room side has two (cased openings) the other side coming from the great room has a pair of doors, then into the barrel vault going out into the 2-way cathedral vault (which will be complete when I finally add the second floor above and make that space open below). I was waiting on modeling the second floor since the Owner has made a gzillion floor plan changes just on the first floor. He explained to day (after a dozen emails and texts) that he is "Design OCD"!!!!
Thanks for any direction given.
YARBRO_RESIDENCE_ADDITION.plan
Uncheck Flat Ceiling.
Use the object Eyedropper to transfer the settings from one room to the other.
The walls around the safe room seem misaligned.
Brick ledge?
Steep stairs.
ct5.thumb.png.7d080fb46cdb2b5b9e6d01ee10a1ba9e.pngct6.thumb.png.65c0a99f15243261f6499a0803042a92.png
Eric..... no one will believe me but I can get it lined up next time I open the plan it’s tight back like that. I even pulled the wall back re connected it was fine close open its right back like that, deleted the wall redrew lose / open the program right back like that.  I bet the eye dropper trick won’t work for me,,,,,, I’ll try it when I’m back at work tomorrow. Meanwhile thank you.
Eric, wonder why the corners of the wall on the good barrel vault are clipped off at an angle but not on the side you did with the eye dropper.
Because I fixed the ceiling plane on that side. Pull the sides back and snap to the wall.
I know......I fix it every time I open the plan to work on it, and it is fine when I close it until next time I open it, then it's right back like this.
I even pulled the wall all the way back to the corner and drag it back and it will look just fine until I open it again. I tried doing the wall with two walls (one inside like furring and it was worse than this).
Brick ledge?  I haven't built the foundation. I plan on having a brick ledge but really hadn't worked on that.
Steep stairs. Another work in progress, I hadn't adjusted the stairs yet, since I hadn't built the second floor.....is that a NO NO?
? Not sure where this is, I had something similar on the fire place I added in the exterior logia area, but found the issue and thought I had fixed it? I'll take another look at the Living room FP.
Eric, thanks for the added help!!! I don't know how much time to spend doing this stuff.....but I sure do appreciate every second of it!!!!!!!!!!
Eric, I couldn't get the Object Eyedropper to work for me on the barreI  vault, but I did pull a wall section through the good BV, copied, and pasted it in the other two areas I needed the BV in, adjusted them manually and they're good.
Also, fixed the wall intersection (Living room fire place wall) by using the Edit Wall Layer Intersections tool.  Same thing on fixing the Safe room wall (one more time) hopefully it will stay this way?
While taking a closer look at that corner I noticed my wall wasn't framing to the "edge of slab" as I had originally set, so I adjusted that also.  I'll work on the brick ledge and stair later.
As always thanks for the GREAT help!
I used the Object Eyedropper to transfer ROOM settings.
Don't understand why when I copied/reflected the existing barrel, it was in a different location, but duplicating the room settings fixed it.
Are you doing this in that central area?
Eric, it didn't work for me either, but I got it.  The center is open to the roof over the second floor. The roof over this area will be higher than the adjoining roofs and he wants a (I call it 2 way or 2 directional ) vaulted ceiling to form a "pyramid" type vault.  I'm dreading this one too! If he's through making changes today some time I'll start the second floor (then the real fun begins). He just sent me a text and decided he wants fewer lites in all the windows (which I had modelled and mulled as units) based on the Manf. cut sheets he provided, now I've got to explode them and change the lites. I mulled them originally so I could copy and paste them more easily.
Its because the ceilings are set to Use Room Ceiling Finish and the rooms have 2 totally different ceiling finishes defined.  That setting is one of the very first places I would recommend people look when having issues with manually drawn ceiling planes.
Intersecting arched ceilings are called 'Groin Vaults'
Rob, the ceiling in the entry foyer is not a groin. it is going to be cathedral (4 way) to form a pyramid.
That room is not square -- at least in the plan you posted.
Eric, I'm puzzled...…………………...according to the dims, the area of the 4 way is square?
Bob,
Now compare the selected diagonal's length and angle with the other diagonal.
Also have a look at how the selected diagonal meets the bottom left hand corner of the room - zoom right in.
54 minutes ago, glennw said:
Bob,
Well doggone it... I’ll look at it in the morning.
    27831
    Talal1975
    Talal1975
  • Similar Content
    • By robdyck
      Shouldn't a schedule create a logical order automatically? For example, if the first column is "FLOOR" shouldn't they be in order from smallest to largest? If column 2 is "ROOM NAME" shouldn't they be alphabetical? I'm sure they used to be this way... what am I missing? The attached image is of a 'fresh' schedule. It seems pretty random to me.
    • By Evolution
      My search of the forum didn’t bring a topic up addressing this particular question. How do I adjust the size of a perspective view before I send it to layout? Is that in editing the active camera settings?
      When is end to layout it is so small you can’t see any detail. Grabbing the drag handle and doing a concentric enlarge makes the view blurred. I know it is a simple answer, but I haven’t found it yet?
      Thanks
    • By Evolution
      I know this is simple for most of you, but doesn't seem to be working for me.  I set my default for the exterior doors to be "elliptical arched", after several attempts cannot get the doors to have elliptical heads although the frames themselves are. So I know I will look "stupid" for asking help for such a simple task. I tried these topic searches but didn't yield a lot of help.
      I actually do my best to solve my own issues (learning tips and tricks from others)……..and you'd think something this simple...….;the only thing I can come up with is creating a custom door symbol (surely not?)  (EDIT the forum won't let me upload the plan file?). I even drag it into the file upload window but nothing happens. No error message nothing> the plan file is only 18,876 kb so not sure why I can't upload to the forum?
    • By Michaelx
      I have a glass table top that looks like crap with every light in the room reflecting off it like crazy and I can't really see through it. Standard Glass which is the same as the windows and they have no issue. I've turned most of the lights off, no lights close to it, and no outside light. Looks the same in Quick and High Quality. Is there a way to reduce the reflectiveness of a material. I've copied the glass to my User Cat but not really sure what to change.
      X8
    • By Michaelx
      Ver X8. Here's what I'm trying to do. A floating soffit (12" below ceiling) with complex shape and rounded corners. I seems you can't make rounded corners on a soffit. No problem. I can do what I need with polyline solid or custom counter top and it comes out just like I want, but I can't place a recessed ceiling light in/under either of those. I've changed the layer to Cabinet, Soffit but still can't place a light.
