Doug_N Posted September 23, 2019 Share Posted September 23, 2019 This is strange but on floor level 1 only the whole building footprint can be selected, not individual rooms. Anyone have any ideas as to what I have done wrong. This plan is an asbuilt that is in progress. As Built Basement Apartment Zip.zip Link to comment Share on other sites More sharing options...
tommy1 Posted September 23, 2019 Share Posted September 23, 2019 A room definition problem. Check all wall connections. 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 23, 2019 Share Posted September 23, 2019 DJP, see if this helps please Untitled 1.zip Link to comment Share on other sites More sharing options...
Doug_N Posted September 23, 2019 Author Share Posted September 23, 2019 Hi David, Thanks for going through that exercise. I will chase down the problem. Many of the things that you noted like the bathroom wall gap for the furring wall was actually a plumbing chase. There are some very strange items that I wouldn't have done, for example, the masonry wall where the stairs go to the basement. This was a very rough draft of the house just getting to the spot where I was blocking out spaces from the site measurements. Typically in an occupied house, it is really hard to get all measurements that would help to resolve conflicts because of furniture, drapes and sometimes a corner of the house with piles of stored materials. I suspect there is a discontinuity somewhere with one of the interior walls and the exterior walls. But so far I can't find it. Some of the things that you moved make the build not "as-built" but that is such a minor quibble. You found the needle in the haystack, and that is what counts. Thanks David. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 23, 2019 Share Posted September 23, 2019 took a bit to find but this corner is not joined properly , resnap the vertical wall with brick to the concrete wall... just be aware this "chase", Chief will treat as a "room" weird angled wall hidden here causing issues too..... other invisible walls keep trying to pop up the more I played in the plan... Link to comment Share on other sites More sharing options...
Doug_N Posted October 1, 2019 Author Share Posted October 1, 2019 On 9/23/2019 at 12:34 PM, Kbird1 said: took a bit to find but this corner is not joined properly , resnap the vertical wall with brick to the concrete wall... just be aware this "chase", Chief will treat as a "room" weird angled wall hidden here causing issues too..... other invisible walls keep trying to pop up the more I played in the plan... Wow great analysis. Thanks! Link to comment Share on other sites More sharing options...
