Square Edge Dashed Lines
johnny
Johnny,
A couple of alternatives spring to mind.
1. Create a new line style using text in the style - use Character Map to select a square character.
Or, that may not work, try:
2. Use a Distribution Path and distribute a square filled cad polyline block that you saved to the library.
This is a Distribution Path with which you have control of spacing, size, rotation, etc.:
16 hours ago, johnny said:
When i do this in Chief it come out with rounded corners for dash marks.  Is there anyway to make these square?
No. I have asked for more control over the shape of line ends, like exists in other programs:
In this example you can select a flat end with no cap, a round cap (the only option currently available in CA), or a square cap, as well as specify the shape of the corner.
Maybe time for a reminder suggestion.
  • 2 weeks later...
Fully agree!
