Old Software - Video problem - help
BoiseDesigns
I'm sure somebody has seen this before. Were you able to fix it. Is it an adjustment in Chief or the computer. Any help would be appreciated.
Its an X1 program. It was just working on a similar system, but I moved it to a new hard rive and it started distorting only in cut view. please watch the video for full effect.
Thank you
I have chief 7 -21 on my PC's (2) and they all run just fine so I would suspect your PC hardware and your software drivers. The first one I would update would be your video card drivers (update them) and see if that helps. Provided your supporting hardware is good you should have no problems running any version of Chief.
