habdou Posted August 10, 2019 Share Posted August 10, 2019 Does anyone know how to solve this issue with the hinges. Thanks Link to comment Share on other sites More sharing options...
MarkMc Posted August 10, 2019 Share Posted August 10, 2019 Guessing (it helps when you post a plan or part of one) that you made the hinges as part of the door symbol, correct? Two options. 1- make the hinge in two parts- cup on the door and the rest inside the cabinet as the hinge. Might take a little fiddling to get the depth to line up, height should be easy. (until you run into a three hinge cabinet that you want to have two. Other option is using layersets one for door closed another for door open; different doors on different layersets. Have done that with complicated cabinets. That's easiest if you set the open door symbol so that it's open WITHOUT having the DBX open it. You want to only change sets. Link to comment Share on other sites More sharing options...
habdou Posted August 10, 2019 Author Share Posted August 10, 2019 Thank you Mark, The hinge is a symbol, They are attached using Door/Drawer Door Hinges Style from the library. Link to comment Share on other sites More sharing options...
MarkMc Posted August 10, 2019 Share Posted August 10, 2019 That's what I thought, choices are as noted, make two piece hinge symbol or two door symbols. Link to comment Share on other sites More sharing options...
habdou Posted August 11, 2019 Author Share Posted August 11, 2019 Thank you Mark Link to comment Share on other sites More sharing options...
habdou Posted August 11, 2019 Author Share Posted August 11, 2019 Mark, How would you do option #1 with attached file? HingMark.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted August 11, 2019 Share Posted August 11, 2019 2 minutes ago, habdou said: How would you do option #1 with attached file? Separate the hinge with the Delete Surfaces tool or export to Sketchup and use their tools. Link to comment Share on other sites More sharing options...
habdou Posted August 11, 2019 Author Share Posted August 11, 2019 Chopsaw, if you look at the file you will see that the hinge is two parts already. I just need them to work correctly on the cabinet when the door is open or close. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 11, 2019 Share Posted August 11, 2019 4 hours ago, habdou said: Chopsaw, if you look at the file you will see that the hinge is two parts already. I just need them to work correctly on the cabinet when the door is open or close. I think he meant for you to seperate the "cup" from the hinge Arm and place the "Arm" and baseplate on the cabinet and the Cup on/in the Door , this is also what Mark suggested above. whether it will look right I don't know, but is likely the only option as the hinge symbol can't bend like in the real world. M. Link to comment Share on other sites More sharing options...
