joeyp42690 Posted May 27, 2019 Share Posted May 27, 2019 Wanting to do this on a wrap around porch. But don’t know how to get the rafters to be seen.I turned the ceiling off and just shows plywood on the underside. Link to comment Share on other sites More sharing options...
Doug_N Posted May 27, 2019 Share Posted May 27, 2019 If the roof is being generated by a room spec you can delete ceiling layers in the structure dialogue, and then as Eric suggested, build the framing. Link to comment Share on other sites More sharing options...
joeyp42690 Posted May 28, 2019 Author Share Posted May 28, 2019 Eric I have tried that. Link to comment Share on other sites More sharing options...
joeyp42690 Posted May 28, 2019 Author Share Posted May 28, 2019 Sorry it 's taking me awhile to reply back, I'm at work. Link to comment Share on other sites More sharing options...
rlackore Posted May 28, 2019 Share Posted May 28, 2019 On 5/27/2019 at 10:37 AM, Doug_N said: ...delete ceiling layers in the structure dialogue... Try what Doug says: Room Specification>Ceiling>Ceiling Finish>Edit and delete the layers. Link to comment Share on other sites More sharing options...
joeyp42690 Posted May 28, 2019 Author Share Posted May 28, 2019 Will do this once I get a chance. I had specified that the room shouldn’t have a ceiling but it did that instead. I don’t know why. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 28, 2019 Share Posted May 28, 2019 48 minutes ago, joeyp42690 said: Will do this once I get a chance. I had specified that the room shouldn’t have a ceiling but it did that instead. I don’t know why. You specified it should not have a "flat" Ceiling is my guess so you get the Sloped ceiling instead ...with the default material used. You also need to do you Forum Signature , like most others and let people know you are using X6 not X11 as the answers for your questions could be dramatically different these Days... *** To do your Signature .... go up to the top Right Hand Corner above and click on your UserName> Account Settings> Signature.... and enable Signature (will Turn Green) then add your Hardware Details and Chief Software Version, as different Version require different Answers. Mick Link to comment Share on other sites More sharing options...
joeyp42690 Posted May 30, 2019 Author Share Posted May 30, 2019 Thank you everyone for the help. I got it. Link to comment Share on other sites More sharing options...
