TwinMotion
R_Faber
37 minutes ago, CARMELHILL said:
Is it just me
It is a little awkward because they've moved stuff around. The tools and settings seem pretty much the same once you find where they've been moved to, but for me at least, it all works faster and smoother.
  • 1 year later...
I'm struggling to figure out what format to export my renderings in order for them to show up as an importable item in TwinMotion? Nothing I do seems to be able to import into TwinMotion? Any thoughts would be very helpful!
From a 3D view in Chief, select export as 3DS or DAE Collada model from the File menu.
Inside TM select import from the file menu.
important! When your file explorer opens up make sure to change the file type at the bottom because it will probably be set to a file type that isn’t 3DS or DAE.
Change the type to, “all files” and you will then be able to select your exported model, whether it was 3DS or DAE or any of the other accepted types.
If you still don’t see your model, it’s because it isn’t in view. On the right side of the screen, expand the file structure box and highlight your model, then press the “f” key.
  • Like 2
Nailed it! Thanks Michael!
  • 2 weeks later...
    30062
    oldmillhomes
    oldmillhomes
