Molding on Barrel Ceiling
Adam_Gibson
Although the molding will only be 1/2" thick, I assume what I'm attempting is to coffer a barrel ceiling. I've tried with ceiling planes and with polyline solid. I prefer the look of the p solid because the arch can be much more fluid if I break the arch (see close up of yucky barrel just below the more fluid one). Either way, I can't figure out how to apply molding to either so it matches the arch.  Heck, I wish I could just apply cabinet doors to form the arch. Any suggestions would be much appreciated.
LANZA KITCHEN 01.plan
You can use a bow front cabinet-sides and back as just openings. Delete a few surfaces in 3D, convert to a symbol and rotate the symbol. Getting the curves right is likely easier done other ways where you can use a CAD detail to get the curves. But it can be done.
29 minutes ago, solver said:
These are molding polylines. I used a square edged molding, but they could have a edge profile.
ct1.thumb.png.bb3095c3fe6b9f6b2ad74eb162079019.pngct2.thumb.png.7d671fc48b2876e66feefc2631743eec.png
Eric, would you mind explaining your steps? I'm having a difficult time getting molding lines to generate in elevation view, which is where I assume you did this? Please?
16 hours ago, solver said:
Looks good -- how did you do it?
I followed your instructions! Although, I couldn't figure out the part about a  point marking the radius and using the Transform/Replicate to copy and rotate the p-solid about the point. I thought I had a good handle on that tool, but apparently not. Thank you so much!
I see! That's a much better method. I simply did it manually. Once I'd done the left half I copied and reflected about the center object. My method would have resulted in hair pulling if there'd been more than a couple of p-solids to manipulate. Thanks again for the lesson!
