Adam_Gibson Posted April 15, 2019 Share Posted April 15, 2019 Although the molding will only be 1/2" thick, I assume what I'm attempting is to coffer a barrel ceiling. I've tried with ceiling planes and with polyline solid. I prefer the look of the p solid because the arch can be much more fluid if I break the arch (see close up of yucky barrel just below the more fluid one). Either way, I can't figure out how to apply molding to either so it matches the arch. Heck, I wish I could just apply cabinet doors to form the arch. Any suggestions would be much appreciated. LANZA KITCHEN 01.plan Link to comment Share on other sites More sharing options...
solver Posted April 15, 2019 Share Posted April 15, 2019 17 minutes ago, Adam_Gibson said: I assume what I'm attempting is to coffer a barrel ceiling. Is that the look you want to create? A grid with moldings going in 2 directions? Link to comment Share on other sites More sharing options...
Adam_Gibson Posted April 15, 2019 Author Share Posted April 15, 2019 Yes, exactly! Link to comment Share on other sites More sharing options...
Chopsaw Posted April 16, 2019 Share Posted April 16, 2019 Adam, If you have any issues figuring it out give me a shout. 1 Link to comment Share on other sites More sharing options...
MarkMc Posted April 16, 2019 Share Posted April 16, 2019 39 minutes ago, Adam_Gibson said: Heck, I wish I could just apply cabinet doors to form the arch. You can use a bow front cabinet-sides and back as just openings. Delete a few surfaces in 3D, convert to a symbol and rotate the symbol. Getting the curves right is likely easier done other ways where you can use a CAD detail to get the curves. But it can be done. 1 Link to comment Share on other sites More sharing options...
solver Posted April 16, 2019 Share Posted April 16, 2019 These are molding polylines. I used a square edged molding, but they could have a edge profile. 1 Link to comment Share on other sites More sharing options...
Adam_Gibson Posted April 16, 2019 Author Share Posted April 16, 2019 29 minutes ago, solver said: These are molding polylines. I used a square edged molding, but they could have a edge profile. Eric, would you mind explaining your steps? I'm having a difficult time getting molding lines to generate in elevation view, which is where I assume you did this? Please? Link to comment Share on other sites More sharing options...
solver Posted April 16, 2019 Share Posted April 16, 2019 Draw Arc in elevation following ceiling. Convert Curve To Polyline to increase the number of segments making the molding smooth. Convert to 3D Molding Polyline. Space as required. I might make the molding into a symbol for easier placement. For the pieces running front to back, you will need a profile with a curved bottom. If you make this from a p-solid, or a symbol from a molding, you may be able to copy and rotate around the radius of the ceiling. 1 Link to comment Share on other sites More sharing options...
solver Posted April 16, 2019 Share Posted April 16, 2019 16 minutes ago, solver said: If you make this from a p-solid, or a symbol from a molding, you may be able to copy and rotate around the radius of the ceiling. Looks like a p-solid can be rotated in elevation, but not a molding or symbol -- can't seem to select them. 1 Link to comment Share on other sites More sharing options...
solver Posted April 16, 2019 Share Posted April 16, 2019 Molding Polyline arched to match ceiling. Converted to a symbol. Used it as a background to draw a profile against so I could match the curve. Converted profile to a p-solid. Placed the center p-solid, then placed a point marking the radius. Used Transform/Replicate to copy and rotate the p-solid about the point. 1 1 Link to comment Share on other sites More sharing options...
Adam_Gibson Posted April 16, 2019 Author Share Posted April 16, 2019 Thanks, Eric! I'm going to try today. I really appreciate this! Link to comment Share on other sites More sharing options...
Adam_Gibson Posted April 16, 2019 Author Share Posted April 16, 2019 I've got it! But Eric, I like the way yours looks better. Would you mind posting the plan? If not, I understand. Thanks so much! 1 Link to comment Share on other sites More sharing options...
solver Posted April 16, 2019 Share Posted April 16, 2019 1 hour ago, Adam_Gibson said: Would you mind posting the plan? LANZA KITCHEN 01 (eric).zip 1 Link to comment Share on other sites More sharing options...
Adam_Gibson Posted April 16, 2019 Author Share Posted April 16, 2019 You're too kind. Thanks, Eric! Link to comment Share on other sites More sharing options...
HumbleChief Posted April 16, 2019 Share Posted April 16, 2019 Great thread, great tip Eric. Thanks Link to comment Share on other sites More sharing options...
Adam_Gibson Posted April 16, 2019 Author Share Posted April 16, 2019 Thanks so much for your help. This is the idea I had in the middle of the night, and now I'm able to show my client, thanks to you! Link to comment Share on other sites More sharing options...
solver Posted April 16, 2019 Share Posted April 16, 2019 Looks good -- how did you do it? Link to comment Share on other sites More sharing options...
Adam_Gibson Posted April 17, 2019 Author Share Posted April 17, 2019 16 hours ago, solver said: Looks good -- how did you do it? I followed your instructions! Although, I couldn't figure out the part about a point marking the radius and using the Transform/Replicate to copy and rotate the p-solid about the point. I thought I had a good handle on that tool, but apparently not. Thank you so much! Link to comment Share on other sites More sharing options...
solver Posted April 17, 2019 Share Posted April 17, 2019 How did you place these? That seems like the tricky part of this process. Here is what I did. Took the radius of the ceiling and placed a point there. Selected the center trim and copied/rotated it around the point. Taking a couple of angles gave me the info needed to space things evenly. 1 Link to comment Share on other sites More sharing options...
Adam_Gibson Posted April 17, 2019 Author Share Posted April 17, 2019 I see! That's a much better method. I simply did it manually. Once I'd done the left half I copied and reflected about the center object. My method would have resulted in hair pulling if there'd been more than a couple of p-solids to manipulate. Thanks again for the lesson! Link to comment Share on other sites More sharing options...
