EconBlueprints Posted March 8, 2019 Share Posted March 8, 2019 I am trying to remove a room divider but for some reason it just will not go away. It is on the second floor. Anyone have the answer? Thanks, Lane 02-05-2019 Terelli Colonial Plan File.plan Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted March 8, 2019 Share Posted March 8, 2019 Is it a room divider that you placed manually or is it one placed by CA when say you have an independant room within a room, the latter can't be removed. Link to comment Share on other sites More sharing options...
EconBlueprints Posted March 8, 2019 Author Share Posted March 8, 2019 Oh, yes, I have and independent room and I did not create the divider. Got it now, thanks! Lane Link to comment Share on other sites More sharing options...
tommy1 Posted March 8, 2019 Share Posted March 8, 2019 Just put that room divider on its own layer and turn it off in plan view if you don't want to see it. Link to comment Share on other sites More sharing options...
EconBlueprints Posted March 8, 2019 Author Share Posted March 8, 2019 It disappeared as if by magic when I connected the interior room to an exterior wall. The interior room was the stairwell I was working around and I did not realize Chief placed the room divider automatically, which it appears it does so the room is connected and does not try to make the walls exterior walls. Thanks! Lane Link to comment Share on other sites More sharing options...
DavidJames Posted March 8, 2019 Share Posted March 8, 2019 This is happening because you have the "connect island room" option turned on (I believe this is on by default). Turning it off will allow you delete the room divider as well as prevent it from happening going forward. Link to comment Share on other sites More sharing options...
Dermot Posted March 8, 2019 Share Posted March 8, 2019 I recommend that you do not turn off the Connect Island Rooms option. Turning this off will mean that you will have to manually connect all of your island rooms. If you forget, then a number of things in the program may not work correctly. You will likely have problems with room related information including floors, ceilings, moldings, and other structural issues. If you don't like where the program has automatically added the room divider, then add your own room divider and then delete the one the program put in for you. If you don't want to see them, then turn off the layer. Link to comment Share on other sites More sharing options...
