jenmarsch Posted February 27, 2019 Share Posted February 27, 2019 I need to be able to draw these in and I cannot figure out how to do it. I use 10X. Any guidance would be greatly appriciated Link to comment Share on other sites More sharing options...
DMDesigns Posted February 27, 2019 Share Posted February 27, 2019 We offer those: https://www.chieftutor.net/our-symbols.html Link to comment Share on other sites More sharing options...
javatom Posted February 27, 2019 Share Posted February 27, 2019 If you need total control over the rails, stiles, and slats, you can use a thin roof plane with roof openings placed where desired. 3 Link to comment Share on other sites More sharing options...
Ridge_Runner Posted February 27, 2019 Share Posted February 27, 2019 1 minute ago, javatom said: you can use a thin roof plane with roof openings placed where desired. Cool idea! (pun intended) Link to comment Share on other sites More sharing options...
SNestor Posted February 27, 2019 Share Posted February 27, 2019 24 minutes ago, javatom said: If you need total control over the rails, stiles, and slats, you can use a thin roof plane with roof openings placed where desired. Now that is brilliant...thanks for the tip Link to comment Share on other sites More sharing options...
jenmarsch Posted February 27, 2019 Author Share Posted February 27, 2019 @solver great idea, I almost have it, but cant seem to get it to angle out. still trying to make it happen, I dont have the same symbol input you have popping up to enter that in Link to comment Share on other sites More sharing options...
jenmarsch Posted February 27, 2019 Author Share Posted February 27, 2019 @javatom I may try that next, Link to comment Share on other sites More sharing options...
javatom Posted February 27, 2019 Share Posted February 27, 2019 If you want to use Eric's idea, you find the controls under the "open symbol" icon. You would then rotate around the X axis with a negative number. Link to comment Share on other sites More sharing options...
jenmarsch Posted March 6, 2019 Author Share Posted March 6, 2019 @solver just getting back to this, I dont have the option of an x axis and I can't find the Louvered window. Link to comment Share on other sites More sharing options...
jenmarsch Posted March 6, 2019 Author Share Posted March 6, 2019 @solversorry I'm such a nube. I think I'm almost there, found the symbol piece, but I cant get it to rotate at any angle. Link to comment Share on other sites More sharing options...
jenmarsch Posted March 6, 2019 Author Share Posted March 6, 2019 got it!!!!!! Link to comment Share on other sites More sharing options...
jenmarsch Posted March 6, 2019 Author Share Posted March 6, 2019 @solver how to angle the louvered windo with larger slats, I'm not seeing the symbol option at the bottom for that one Link to comment Share on other sites More sharing options...
jenmarsch Posted March 6, 2019 Author Share Posted March 6, 2019 no worries, thank you, this will do for sure. I appreciate your time and quick responses. Link to comment Share on other sites More sharing options...
