ACADuser Posted September 15, 2014 Share Posted September 15, 2014 OK I created a bunch of floor trusses just fooling around with the tools & such. Now I want to select ALL the floor trusses & delete them. selecting one truss & there is no "Select similar" option. How do you select all of them? Link to comment Share on other sites More sharing options...
lbuttery Posted September 15, 2014 Share Posted September 15, 2014 use the "all off" layerset then turn on the trusses layer draw a marquee around the trusses and delete Lew Link to comment Share on other sites More sharing options...
ACADuser Posted September 15, 2014 Author Share Posted September 15, 2014 Thanks, seems like a workaround when Select Similar would be the tool of choice. Speaking of layers, say you are working in plan view and you want to hide a few layers to make eslecting objects easyer. You hide several layers & now you layer Set is messed up. Shouldn't you be requierd to SAVE the changes to that layer Set if you wanted a perminant change. No simple way to restore the layers you have hidden? Link to comment Share on other sites More sharing options...
lbuttery Posted September 15, 2014 Share Posted September 15, 2014 why not just turn the layers back on ? you could clone the layerset and then make "changes" to the clone there have been numerous requests to have the Layer display options dbx stay open and have an apply button so that we can "play" with layers on/off Lew Link to comment Share on other sites More sharing options...
lbuttery Posted September 15, 2014 Share Posted September 15, 2014 seems like a workaround when Select Similar would be the tool of choice Hmmm, maybe I haven't used "select same/load same" much Lew Link to comment Share on other sites More sharing options...
ACADuser Posted September 15, 2014 Author Share Posted September 15, 2014 Just so happens that I turned 8 or so layers off & after a time working on that drawing I could not remeber all the layers I had turned off. Looks like I will have to clone the layer set next time, live & learn. I didn't check History to see if the Hide command recorded all my actions. Oh wait I just checked & I can't fins a history? Does Chief record all actions upto a set number for your review? That is tied to Undo in ACAD which reportd to the screen each time you undo it says what action it is undoing, this is very helpful. So neather of these features are in Chief? Link to comment Share on other sites More sharing options...
lbuttery Posted September 15, 2014 Share Posted September 15, 2014 Doe Chief record all actions upto a set number for your review? Nope, not for review Lew Link to comment Share on other sites More sharing options...
rlackore Posted September 15, 2014 Share Posted September 15, 2014 Activate the truss tool: Build>Framing>Floor/Ceiling Truss Now hold down the shift key and window around all the floor trusses - they will all be selected. This behavior works for all kinds of Chief objects; first activate the tool, then shift select. Link to comment Share on other sites More sharing options...
ACADuser Posted September 15, 2014 Author Share Posted September 15, 2014 On 9/15/2014 at 3:47 PM, rlackore said: Activate the truss tool: Build>Framing>Floor/Ceiling Truss Now hold down the shift key and window around all the floor trusses - they will all be selected. This behavior works for all kinds of Chief objects; first activate the tool, then shift select. OH forgot that one already. Thanks Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 15, 2014 Share Posted September 15, 2014 On 9/15/2014 at 3:47 PM, rlackore said: Activate the truss tool: Build>Framing>Floor/Ceiling Truss Now hold down the shift key and window around all the floor trusses - they will all be selected. This behavior works for all kinds of Chief objects; first activate the tool, then shift select. There are times I use this method but somehow it will select something else and won't open the correct edit DBX. Link to comment Share on other sites More sharing options...
ebdesign Posted September 15, 2014 Share Posted September 15, 2014 Quote Activate the truss tool: Build>Framing>Floor/Ceiling Truss Now hold down the shift key and window around all the floor trusses - they will all be selected. This will select ALL framing members (except wall framing) that are displayed & the layer not locked, so be careful. Link to comment Share on other sites More sharing options...
