rockyshepheard Posted February 12, 2019 Share Posted February 12, 2019 How is this even possible? Link to comment Share on other sites More sharing options...
madcowscarnival Posted February 12, 2019 Share Posted February 12, 2019 This seems to be the same plan as the previous post, but the only way I'm aware of to make CA do this is rotating the baseline angle. I've never seen the join tool do that, only manually. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 12, 2019 Share Posted February 12, 2019 Rotating the baseline will do it as will changing the baseline angle along the z axis Link to comment Share on other sites More sharing options...
robdyck Posted February 12, 2019 Share Posted February 12, 2019 On 2/12/2019 at 5:20 PM, rockyshepheard said: How is this even possible? Expand I can make a roof weirder than that as long as I keep my eyes closed! Are you drawing the same plan in 2 different programs? Or just referencing the autodesk file? Link to comment Share on other sites More sharing options...
rockyshepheard Posted February 12, 2019 Author Share Posted February 12, 2019 Just referencing autocad. Link to comment Share on other sites More sharing options...
robdyck Posted February 12, 2019 Share Posted February 12, 2019 And drawing roof planes manually? Or using the 'build roof planes' tool? Link to comment Share on other sites More sharing options...
robdyck Posted February 12, 2019 Share Posted February 12, 2019 If manually, pay close attention that you are dragging exactly along the outside of the main layer of your exterior walls. Gotta keep that roof plane's baseline parallel. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 12, 2019 Share Posted February 12, 2019 On 2/12/2019 at 6:39 PM, robdyck said: Gotta keep that roof plane's baseline parallel. Expand ...unless of course it was rotated for a reason. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 12, 2019 Share Posted February 12, 2019 On 2/12/2019 at 6:17 PM, rockyshepheard said: Just referencing autocad. Expand AH HA...that's never been a problem here before.... Link to comment Share on other sites More sharing options...
