zowie123 Posted February 2, 2019 Share Posted February 2, 2019 Hi All, A few pdfs on a page can sometimes slow things to a crawl. I've monitored my system and can't really pin down what resources it's dragging on. I have an i7-6700 3.4 CPU with a 2080 GPU. 16gig ddr4 ram. I saw a big change in render speed on larger complex houses with the 2080, but relatively no change with pdf bog. The GPUs are stressing with pdf processing, but not at max and memory usage never seems to go above 35%. i'd upgrade to the i9-9900, but I'm not sure it's where the problem lies. Chief can handle more cores than gaming programs, anyone having any luck with AMD 16 core 32 thread Ryzen chips? Thank you, Barry Link to comment Share on other sites More sharing options...
Renerabbitt Posted February 12, 2019 Share Posted February 12, 2019 On 2/2/2019 at 10:04 AM, zowie123 said: Hi All, A few pdfs on a page can sometimes slow things to a crawl. I've monitored my system and can't really pin down what resources it's dragging on. I have an i7-6700 3.4 CPU with a 2080 GPU. 16gig ddr4 ram. I saw a big change in render speed on larger complex houses with the 2080, but relatively no change with pdf bog. The GPUs are stressing with pdf processing, but not at max and memory usage never seems to go above 35%. i'd upgrade to the i9-9900, but I'm not sure it's where the problem lies. Chief can handle more cores than gaming programs, anyone having any luck with AMD 16 core 32 thread Ryzen chips? Thank you, Barry I typically take a screen clipping of a PDF if I don't have access to a program to reduce the PDF's size(which i do). Also checking the box for "save in plan" seems to help with slow downs. Also sometimes its worth it to draw a cad box to where your PDF will be placed and leave importing PDF's to the last step of your CD's I have a 14 core xeon- CA is best suited to speed of CPU vs number of cores, my laptop often outperforms my desktop- see sig Link to comment Share on other sites More sharing options...
JJohnson Posted February 12, 2019 Share Posted February 12, 2019 I have created a new layer called CAD, pdf imports. I assign pdf,s to that layer, and uncheck Display. Link to comment Share on other sites More sharing options...
CharlesVolz Posted February 13, 2019 Share Posted February 13, 2019 I save PDFs as a jpeg, then import the jpeg and save it in plan which solves my PDF slow-down problems. Link to comment Share on other sites More sharing options...
madcowscarnival Posted February 14, 2019 Share Posted February 14, 2019 An additional option that had been given to me in a similar post is use .PNG file type. I believe that PNG offers a better file size to resolution ratio and it barely slows CA down. Especially in details from code where I desire a higher resolution instead of converting a PDF to a higher-res jpg which can become a large file quickly. Link to comment Share on other sites More sharing options...
R_Seales Posted February 14, 2019 Share Posted February 14, 2019 I have been using the .PNG file type for over a year now and it really helps, no more slowing down to a crawl, and the resolution is great. Link to comment Share on other sites More sharing options...
