window labels
marklcc
2 minutes ago, marklcc said:
Is there a way to have a window label associated to schedule and a written label displayed on the floor plan?
Are you talking about the Schedule Callouts perhaps ?  enable it in the Schedule Options>Labels>Use Callout.....pick a shape and text size
44 minutes ago, marklcc said:
I want to display both a schedule callout and written description.
Example below.
Is there a way to do this?
You can turn off Callouts and Specify the Label instead and use the Schedule and width x height macros..... do it in your Defaults>Window and it will be used for ALL Windows from then on. Do it in your Template plan if it's something you want to always have too.
image.thumb.png.39117a9ac231b4221d71b464e830a1dc.png  image.thumb.png.83f90e2cfce829633461bd5587cf6082.png  image.thumb.png.afbd922e9d45f417889b8fa2893ab447.png
Don’t have time to get into it right now, but there are 2 or 3 easier/cleaner/more qualifying approaches too.
Well, it is a macro, but I m not sure where I got it.  I have purchased from Alaskan Son (great stuff) so maybe I got it from him.
I have not had the time to learn how to create my own, but it is on my "to-do" list.
If inches is okay then use the basic %width%x%height%
Also, if the full name takes up too much space then use %type_code% instead of %type_name% for an abbreviated version. I don't know if this is also a purchased macro or if it comes with Chief.
Both are default Macros you can use , to see them all for any object , use a text leader Line and the built in Macro %objectproperties% and the text box will fill with all auto recognise macros you can use in any text or rich text box , just make sure you use the % sign at each end of the named macro  eg ^^^^^^^^^^
