wolfrem68
designing R panel metal roofing
I have X10 Premium and need to place 36" R metal panels on pole barn drawings. Does anyone have instructions to do this? I appreciate the help in advance.
Add them to the Roof Surface or if the Wall , then add them to a new Wall type as the outer Layer....
their is a selection in the Sheetmetal library....
M
I am new to the program and need to have a way to show metal R paneling and have the materials list give me the correct amount of sheets of material.
KBIRD thanks for the reply, can you direct me to the sheet metal area in the library. I am new to the program.
thanks
Chief Architect Core Catalogs > Materials > Sheet Metal.......
I have followed the last two posts and do not have these areas in the library browser.
When you installed the program , did you download the Core Catalog libraries when asked?
if not goto Library >Download Core Catalogs....
Mick.
When you installed the program did it ask you to download Core Catalogs ?   If you did not go to Library > Install Core Content.
Do you want "ribbed" (sometimes called delta rib) metal or "standing seam" metal?  Note that in the library browser you can type in whichever type you want to use in the search box (see the image in Jim's response).
Chopsaw has the Wording correct.....
and you should see this.... assuming Chief Architect Premier X10
Yes that took an extra millisecond but it was hauntingly similar to your post.:blink:
Forgive me for being absent minded. I just realized I had not downloaded the file. I thought it had loaded but obviously not . I am in the process of doing so now
I am getting the download now but I have very slow internet. Thanks to you all.
Steve
Steve
That should give you time to fill out your signature for next time you need help.
With barns there will always be Manual Framing to do too, so while you wait you can do some reading on the KB , there are couple of tuts. on it about Barn structures :
https://www.chiefarchitect.com/support/article/KB-01069/designing-a-traditional-pole-barn-structure.html
and
https://www.chiefarchitect.com/support/article/KB-00598/creating-a-post-and-beam-structure.html
This Test plan of mine may help you get some ideas too...
Metal Barn_X10_MHD.plan
Kbird1,
Thanks for the pics of your pole barn. I had already downloaded the file on Traditional Pole Barn Structure and have followed the instructions. When I attempt to set the trusses in place they show up on the second girt and they look wrong, nothing like the trusses in you pics.
10 minutes ago, wolfrem68 said:
Kbird1,
In my Plan or in the 2nd KB Tut?
Trusses ALWAYS build between the Roof and Ceiling plane so my guess would be that your Ceiling plan is at the default 8' or 9' Ceiling height for the Floor but you have raised the Roof ? just a guess cos you didn't provided the Plan or even a pic or two...
edit: that KB tut is over a year old ( oct 2017) , so some of the settings maybe slightly different in X10 than in X9 , something I have come across before , eg in the Elevated Structures Tutorial which hasn't been update since 2015.
I did fill out my signature.    This is what I get when I place the truss in place. Wall height is 12'.
When I build the roof plane and roof it appears as in the picture. I will resent with roof .
Yep can't miss it now :)  ...apparently you Son is a very nice guy !
When you reset the Roof planes, you then need to select ALL the trusses , Open the DBX and check the force truss Rebuild box too.
Is auto rebuild Roof still on? as those roof planes are not over your new Walls...., and i see trusses at correct height for those roof planes
FYI.....you can't attach the .Plan file while the plan is open in Chief Architect.
    27825
    ChiefDallas
    ChiefDallas
