George Posted September 7, 2014 Share Posted September 7, 2014 Does anyone know how to make material patterns, I have tried the scanning, then .bmp, then rename to .pat to no real success. I have several templates for stone, etc. that would be handy sometime. Thanks for the help in advance. George Link to comment Share on other sites More sharing options...
glennw Posted September 7, 2014 Share Posted September 7, 2014 George, You need to read up on materials and the difference between a texture and a pattern. Any material can have texture (picture which displays in a standard view) and a pattern (cad lines forming a pattern which displays in a vector view) assigned to it. You can't change a texture into a pattern - they are 2 completely different things. Link to comment Share on other sites More sharing options...
Solution CJSpud Posted September 8, 2014 Solution Share Posted September 8, 2014 George: Have you looked at all of Chief's "Custom" pattern folders. If not, you should check them out. There might already exist patterns that are close to what you need. In addition to the default pattern folder that are available when assigning a fill, there are 11 other custom pattern folders of various materials types that are accessible via. custom > browse. Below is a PDF that a fellow Chiefer (???) provided on the forum awhile back that shows the various patterns in those folders. I have printed a copy of this file and use it as a "cheat sheet" reference which is quicker than migrating through the folders to see what is there. Fill Hatch Patterns Cheat Sheets.pdf Here's a copy of a 2001 ChiefTalk thread with some info on doing patterns. Not sure if it will help you figure out how to make a pattern or not. Looks way too complicated for me ... I will make do with what's available and hope the Chief dudes will give us more as time goes on. 4-27-01_TimO-PatternFiles.pdf Here's a Joe Carrick thread from 2007 that has more information on the subject: Creating Fill_Hatch Patterns_JoeCarrick.pdf If I can find more info I've saved from old threads I will post it. Will probably have to go looking on my old computer to find more. If you haven't explored the custom fill folders yet, here's a few images on the subject: You can tweak the settings of your materials to get the pattern to display at different scales. Maybe you've already figured all that out. 2 Link to comment Share on other sites More sharing options...
lbuttery Posted September 8, 2014 Share Posted September 8, 2014 I bought this Hatch Editor back in 2005 when first getting started we never used it so I can't say if it is good or not.... it does have a free trial may be handy if you are serious about creating hatch patterns http://www.hatchkit.com.au/index.php Lew Link to comment Share on other sites More sharing options...
George Posted September 9, 2014 Author Share Posted September 9, 2014 Thanks for the input, I was trying to add new patterns, I had been to the custom files, but really wanted a few more, I have burnish templates (now telling you I bought these in 1973 and some still in original plastic as I bought two sets) these where the thing when doing vellum drawings. They did good for the time, but I wanted to adapt to chief now as many of them are ahead of Chief patterns. I have tried the .bmp and then .bmp to .pat --no luck--I can only scan and then try to adapt. Maybe this defines the problem, there may be no solution, but the chief techs say there is a way Link to comment Share on other sites More sharing options...
