Roof Help
AbeLopez
One solution: you could add another floor added to your building. Then draw some walls for the small secondary roof and make your roof planes and then adjust their height down to the proper position. The small projection to the front for the mini window dormer should be an easy grab of the roof eave to drag it out for the extension. You can do the same thing without adding the floor. If so, just delete the walls after you create the roof planes or make them invisible walls.
I just copy the plan to another plan file, lock the walls, and use it as a worksheet Then when you get each different roof the way you want just copy hold ,back to the plan. Manual roof knowledge is a must. That looks like an extra charge to me.
