Importing Materials in Bulk
stager386
Not that I am aware of. What you should do is to place the image files in the C:/My Documents/Chief Architect Premier X10 data/Textures. Then you use the Library Browser to, one at a time create a "New Material" for each texture file, naming it and importing it into the Library Browser. That is the only method I know of.
Place all your images into a single folder and sub folders if you like.
3D...Materials...Convert Textures To Materials.
Select a folder and Chief will convert all the textures in that folder ( and sub folders) to your library in one go.
It will also create the materials with the same folder heirachy as the original textures.
That's exactly what I did, thank you. I was just hoping I could somehow do it in bulk.
Oh wow, thank you! It worked!
I am trying to take these materials, and add them onto a portion of an object.  For example, I want to decorate the rim of a plate with a design but leave the rest of the plate plain.  I have tried playing around with polylines and material regions and custom backsplashes, but none are really doing the right thing.  Any thoughts on that? Thank you.
That is a rather delicate thing to do in Chief but the theory would be to have separate materials on the symbol such that they could be edited afterwards. You could carefully add a thin layer to an existing symbol or start from scratch and model your own components.
This is what I have been trying to do, adding a thin layer around the plate. but I can't edit the polyline , the part I want to make into a "donut" to sit on the rim, to become a circle. And the solid shaped poly cylinder can't have a hole cut out of it to become the donut.
On 9/16/2018 at 9:19 PM, Chopsaw said:
Hopefully this will help:
Thank you for taking the time to do this!  I ended up creating the extra surface on the plate by making a polyline solid and converting to a spline. It then became the round shape I needed.  Then created a copy of the new round polyline, sized it smaller, and created a hole in this copy. This copy, is now completely a hole. I placed it on top of the larger round polyline and then both on top of the plate.  3 components.  Not very efficient but it worked, and I will now try your method.  Thank you so much!
