CHANGING LAYOUT SHEET SIZE AFTERWARDS
mtldesigns
I need to change an existing drawing (layout) from an arch D to an arch E size (builder request).  Is there anyway to do this without starting over?  The existing template is arch D, and I do have an Arch E. I was hoping for an easy swap out, but I am stumped.
Thank you in advance.
so basically on page 0, redo the temp-plate to an Arch E size, adjust paper size, etc..... ?  not bring in a Arch E existing layout?  Genius!
Thanks Chop...  I was thinking I had to delete the D and insert an E...  this  makes sense, the layout is not a block as it would be in a dwg file.
