verticalworks Posted September 8, 2018 Share Posted September 8, 2018 I have an upper cabinet that extends past a railing wall below that is cutting off the crown molding on the wall cabinet. I cannot seem to find a option or work around. Any thoughts? Link to comment Share on other sites More sharing options...
verticalworks Posted September 8, 2018 Author Share Posted September 8, 2018 Well that was easy, Thanks! Link to comment Share on other sites More sharing options...
Kbird1 Posted September 8, 2018 Share Posted September 8, 2018 You can use a Material Region or Custom BS for the backsplash tile to fix it around the Window and at the end over the 1/2 wall if needed but adjusting the base cabinet BS to 18" ( counter to bottom of Upper cabinet) may also do it for you... Link to comment Share on other sites More sharing options...
verticalworks Posted September 8, 2018 Author Share Posted September 8, 2018 Another similar issue with a railing wall, how to you get the ceiling not to cut through? Link to comment Share on other sites More sharing options...
Kbird1 Posted September 8, 2018 Share Posted September 8, 2018 27 minutes ago, verticalworks said: Another similar issue with a railing wall, how to you get the ceiling not to cut through? I would say don't use a railing wall for a fireplace if that is what you have done? Apply the Brick/stone to a Solid or a Soffit even, instead and use a 2nd one for the Mantel M. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 9, 2018 Share Posted September 9, 2018 Justin, I thought I had experienced that sort of problem before and managed to resolve it but could not reproduce the failure in a test plan. Would you mind copying that into a test plan and posting it if you have a moment. Link to comment Share on other sites More sharing options...
verticalworks Posted September 9, 2018 Author Share Posted September 9, 2018 I have attached plan, thanks for the help solver & chopsaw VWI-Brandon-17_09_08.18.plan Link to comment Share on other sites More sharing options...
verticalworks Posted September 9, 2018 Author Share Posted September 9, 2018 Interesting, I just re-drew as well and now its works. I even pulled away and put back and still treated it the same. But drawing a new wall again works. Thanks for the help! Link to comment Share on other sites More sharing options...
Chopsaw Posted September 9, 2018 Share Posted September 9, 2018 I get the same but would love to know what is going on. Will look into it further if I can. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 9, 2018 Share Posted September 9, 2018 That is weird ..even after deleting the wall the Main Room shape doesn't fix itself hmmmm F12 fixed the 3D view but not the plan view..... looks like you had a hidden power outlet and coax you need to raise up behind the TV too. Link to comment Share on other sites More sharing options...
MarkMc Posted September 9, 2018 Share Posted September 9, 2018 Guessing - room or room molding polyline? Link to comment Share on other sites More sharing options...
