basilbabaa Posted August 28, 2018 Share Posted August 28, 2018 I need to make a railed walls with following configuration: Rails: 2.5"h x 5"w Newels: 2.5"w x 5"l Beam: 2.5"h x 5"w Since Chief only allows for round or square and not rectangular newels & balusters, how can I create a library rectangular Baluster/Newel post that is 2.5"w x 5"l Link to comment Share on other sites More sharing options...
Chopsaw Posted August 28, 2018 Share Posted August 28, 2018 https://www.chiefarchitect.com/support/article/KB-02893/creating-custom-balusters-and-railing-panels.html 1 Link to comment Share on other sites More sharing options...
SNestor Posted August 29, 2018 Share Posted August 29, 2018 Newels in Chief...you can make your own or customize the deck rail many ways. Here's a quick video...hope it helps you out. Link to comment Share on other sites More sharing options...
Douglas49 Posted August 31, 2018 Share Posted August 31, 2018 Hi Steve Nice video again. There appears to be a variety of objects one can use to build a shape from - counter tops/ slabs/ box/ polyline solids/ even the old cabinet soffit tool, plus starting from polylines and converting. Is there any reason why one would be chosen over another - which object is becoming the go to one people mostly use? The soffit tool and the counter top have the moulding link built in, which is handy, but there appears to be other no differences - all methods produce the same end result. Link to comment Share on other sites More sharing options...
basilbabaa Posted August 31, 2018 Author Share Posted August 31, 2018 Thanks. Love the video. While I've successfully created a newel post with the dimensions 2.5"x5"x6' tall, I still cannot seem to get the railing to be rectangular. No matter what I do, when I add my 2.5"x5" newel post into my 5" wide railing wall, when I set the Newel post width to 2.5" it makes it a square 2.5", and if I set the newel post width to 5" it again makes the a square 5"x5"... I need a galvanized steel frame wall 5" wide with 2.5"x5" newels spaced ever 60 inches. I've included my symbols and the wall I'm trying to put it in...Steel Frame Wall.calibz Any more tricks I can try? 2.5%22x5%22 Post.calibz Link to comment Share on other sites More sharing options...
Chopsaw Posted August 31, 2018 Share Posted August 31, 2018 Basil, I thought maybe I had lead you in the wrong direction and had not tested the theory. However I just ran a test and it seems to work fine. Take a quick check on your railing height and see if that helps. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 31, 2018 Share Posted August 31, 2018 2 hours ago, basilbabaa said: Thanks. Love the video. While I've successfully created a newel post with the dimensions 2.5"x5"x6' tall, I still cannot seem to get the railing to be rectangular. No matter what I do, when I add my 2.5"x5" newel post into my 5" wide railing wall, when I set the Newel post width to 2.5" it makes it a square 2.5", and if I set the newel post width to 5" it again makes the a square 5"x5"... I need a galvanized steel frame wall 5" wide with 2.5"x5" newels spaced ever 60 inches. I've included my symbols and the wall I'm trying to put it in...Steel Frame Wall.calibz Any more tricks I can try? 2.5%22x5%22 Post.calibz Hi Basil , perhaps you can explain with an image or something what you are trying to do so we can help more as there are issues with your post and wall The Post symbol says it is 4"x4" x 36" but it's biggest issue is it is orientated incorrectly and I can't seem to rotate it in the symbol DBX to get it correct , in the image below I made my own to fix that but as you can see a 2.5 x 5" Newel post doesn't work at the Corners , will they really be 5" x 5" ? the Railing Wall is set Post to Beam ? and the railing is only 2.5" high ? ( 42" is STD height ) I have a feeling you should read through the help for that DBX (F1 while open) so you can set things up correctly ...I also changed the "wall" in my pic below to what I though it maybe that you want ? but are sure... M. Link to comment Share on other sites More sharing options...
