Doug_N Posted August 26, 2018 Share Posted August 26, 2018 Does anyone have any idea why this is happening? The roof plane cuts through the ceiling plane so that near the exterior wall the ceiling is the bottoms of the roof rafters. Link to comment Share on other sites More sharing options...
javatom Posted August 26, 2018 Share Posted August 26, 2018 It could be a previous auto frame and then you changed some walls, ceilings etc. Try rebuilding the ceiling framing. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 26, 2018 Share Posted August 26, 2018 Just now, javatom said: It could be a previous auto frame and then you changed some walls, ceilings etc. Try rebuilding the ceiling framing. Was just thinking the same thing..... Link to comment Share on other sites More sharing options...
Doug_N Posted August 26, 2018 Author Share Posted August 26, 2018 Yes I did that before posting this. But here is a regen of the framing for the ceiling and the roof Ceiling through roof plane.mp4 Ed Markoulakis-PLC_DELL_LT aug 20.plan Link to comment Share on other sites More sharing options...
javatom Posted August 27, 2018 Share Posted August 27, 2018 Check your room definitions. You have a layer of drywall within the structure tab AND a finished layer of drywall. The doubling up of ceilings is confusing the framing. Delete the one under the structure tab and rebuild the framing and you will be fine. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 27, 2018 Share Posted August 27, 2018 Doug, You also have a bunch of rooms set to "Use Soffit Surface For Ceiling" which is seriously weakening your rafter spans. Link to comment Share on other sites More sharing options...
Doug_N Posted August 27, 2018 Author Share Posted August 27, 2018 Thank you gentlemen. Both of the observations and suggestions were very helpful and have solved the problem. Link to comment Share on other sites More sharing options...
