Switchback Stair clearance / opening
ACADuser
Looking at the minimum width opening required for interior residential stairs I came up with 6'-6 1/4" drywall to drywall.
That is given a 2" handrail, 1-1/4" balusters and a 1" side tread overhang.
Does that look correct to you folks?
Thanks
According to the CRC which I believe is exactly the same as the IRC:
  Minimum width above handrails is 36".
  Handrails are allowed to project as much as 4.5" into the 36" minimum width
  Minimum width at and below handrails is 31.5" when the handrail is only on one side.
  Minimum width at and below handrails is 27" when the handrail is on both sides.
  Based on the above, assuming no tread overhang on the open sides you can have a switchback stairway of 6'-0" drywall to drywall.
Note that a "Guard" on the open sides could actually be at the same location as the handrail.
