MarkMc Posted August 6, 2018 Share Posted August 6, 2018 Short story-here is a 3 wire tray base pullout representing a Hafele 546.62.826 with 546.63.114 (set and a half) two cabinets and the insert. Base width is 14" but can resize that-height is set for a frameless cabinet that with 4" toe kicks but you can copy it in your library and resize for others. If you want two baskets well you will have to work on that yourself (I have wooden things made by the mfg) Long version if you care Melissa was placing a wire pullout in a base cabinet and ended up using one meant for a tall cabinet. The only wire 3 tray PO that I know of is from Hafele-a few widths are available and the height is adjustable but you can't go and (reasonably) get a custom wire P.O. Some of the Hafele catalog is available in 2020 BUT not in Chief. (get after your Hafele rep and cabinet suppliers to change that). You can export a 3d DWG from 2020 but still have to get textures onto it-ugh. Hafele now has a 3D database which is awful to rummage through and the face counts get atrocious. Anyway-. being unable to resist a rabbit hole and to escape playing with Ruby and paperwork I put this together. Just needed a break. Base PO cabinet.plan 1 Link to comment Share on other sites More sharing options...
pgjacob Posted August 6, 2018 Share Posted August 6, 2018 Wow, that is great! Looks like you did alot of tinkering, but very nice! Link to comment Share on other sites More sharing options...
MarkMc Posted August 6, 2018 Author Share Posted August 6, 2018 2 minutes ago, pgjacob said: Wow, that is great! Looks like you did alot of tinkering, but very nice! No tinkering-made from scratch in Chief-you can too with a tad of practice Link to comment Share on other sites More sharing options...
MarkMc Posted August 6, 2018 Author Share Posted August 6, 2018 OOPS- noticed a mistake- open symbol and uncheck Uniform stretch zones- should be stretch planes Link to comment Share on other sites More sharing options...
Kbird1 Posted August 7, 2018 Share Posted August 7, 2018 Thanks Mark , looks nicely done... Link to comment Share on other sites More sharing options...
Cheryl_C_Crane Posted August 7, 2018 Share Posted August 7, 2018 Mark, Thanks very much! Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 7, 2018 Share Posted August 7, 2018 Thank you, Mark! DJP Link to comment Share on other sites More sharing options...
Paul454 Posted August 8, 2018 Share Posted August 8, 2018 Thanks Mark! Great Job! Link to comment Share on other sites More sharing options...
NRST8TRKR Posted August 10, 2018 Share Posted August 10, 2018 Thank you,Mark, Have a great weekend,Ken Link to comment Share on other sites More sharing options...
expodesigngroup Posted August 12, 2018 Share Posted August 12, 2018 Terrific, thanks so much! Link to comment Share on other sites More sharing options...
