scout1 Posted August 2, 2018 Share Posted August 2, 2018 If I use a section camera as a callout and put it on a layer should I be able to turn that callout off in different plan views Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 2, 2018 Share Posted August 2, 2018 Yes, that works. Just set that layer to not display in the plan views where you don't want to show it. There is also a setting in the Camera dbx for "Display on All Floors" which can be useful. 1 Link to comment Share on other sites More sharing options...
scout1 Posted August 2, 2018 Author Share Posted August 2, 2018 thanks for the answer but if I start new plan that works. In the plan I am working on the section camera callouts don't want to turn off. Is there possibly a setting somewhere that would not let the callout be turned off. if I insert a callout they behave correct. only camera used as callouts don't work. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 2, 2018 Share Posted August 2, 2018 I tried it on an existing plan. I changed the layer of a Cross Section Camera to a new Layer which I created. Then in another Saved Plan View that didn't use the same Layer Set I unchecked that layer for display. It worked perfectly. When I switched back to the first Saved Plan View the Cross Section Camera was displayed. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted August 2, 2018 Share Posted August 2, 2018 2 hours ago, scout1 said: Is there possibly a setting somewhere that would not let the callout be turned off. What is sometimes confusing is when a camera view is open it will always be visible even when turned off. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 2, 2018 Share Posted August 2, 2018 8 minutes ago, Chopsaw said: What is sometimes confusing is when a camera view is open it will always be visible even when turned off. 3D>3D View Defaults--Uncheck "Always Display Active Cameras" 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted August 2, 2018 Share Posted August 2, 2018 Thanks Michael. I did not know that was an available setting. It must be on by default. Very helpful. Link to comment Share on other sites More sharing options...
misterwiley Posted August 25, 2018 Share Posted August 25, 2018 On 8/2/2018 at 3:06 PM, Alaskan_Son said: 3D>3D View Defaults--Uncheck "Always Display Active Cameras" This has bugged me for years, so glad this option is available. Thanks so much for sharing! Link to comment Share on other sites More sharing options...
