Aamir77 Posted July 17, 2018 Share Posted July 17, 2018 Hi, I want to make a double dual door in a wall like I am posting in a figure. I did not find a proper way to do so. What I did, I copied the door in place and changed its direction to the opposite side. Am I right? I feel I am not right. Would anyone bother to guide me the proper procedure? Link to comment Share on other sites More sharing options...
Kbird1 Posted July 17, 2018 Share Posted July 17, 2018 Are you trying to show a Door that swings both ways in Plan View or will there physically be two doors? If you are only showing it swinging both ways there is a checkbox in the Door's DBX for that..... Link to comment Share on other sites More sharing options...
Gawdzira Posted July 17, 2018 Share Posted July 17, 2018 I am guessing that you just want the one door to swing both directions? If so, see the image. Link to comment Share on other sites More sharing options...
Gawdzira Posted July 17, 2018 Share Posted July 17, 2018 I am losing my edge. Good thing we were not using pistols at 20 paces. Link to comment Share on other sites More sharing options...
Aamir77 Posted July 17, 2018 Author Share Posted July 17, 2018 I want physically two doors, a framed door with steel mesh to open inward and a solid door to open outward. Link to comment Share on other sites More sharing options...
Aamir77 Posted July 17, 2018 Author Share Posted July 17, 2018 8 minutes ago, Kbird1 said: Are you trying to show a Door that swings both ways in Plan View or will there physically be two doors? If you are only showing it swinging both ways there is a checkbox in the Door's DBX for that..... I knew that but I want two different doors. Link to comment Share on other sites More sharing options...
Aamir77 Posted July 17, 2018 Author Share Posted July 17, 2018 8 minutes ago, Gawdzira said: I am guessing that you just want the one door to swing both directions? If so, see the image. nopes... I want two doors in a wall. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 17, 2018 Share Posted July 17, 2018 you could place a Doorway of the correct size , then add the Door Slabs manually from the library... *** Or add the Steel Mesh door( security?) manually to a normal Door , perhaps made from a Solid or Soffit and metal mesh material https://www.chiefarchitect.com/3d-library/index.php?r=site/detail/961 Link to comment Share on other sites More sharing options...
Chopsaw Posted July 17, 2018 Share Posted July 17, 2018 It looks to me that what you did is working fine. Just need to edit the style. Usually to have two doors in one opening one of them needs to be slightly offset a bit to work. I think usually the height is the easiest to offset but it looks like your method worked. Link to comment Share on other sites More sharing options...
Aamir77 Posted July 17, 2018 Author Share Posted July 17, 2018 With the way I adopted, there are some problems with rendering. First, in render view, both the doors sometimes show and sometimes do not show up, second when I try to edit materials of one of them both disappears in render view and lastly there is another problem in render view which is shown in the picture attached. Link to comment Share on other sites More sharing options...
Gawdzira Posted July 17, 2018 Share Posted July 17, 2018 I would probably fake the second door for the rendering with a poly solid or some other custom object. It does not make sense that there is not an option for a screen door as you are trying to create. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 17, 2018 Share Posted July 17, 2018 Try placing the extra door in the wall beside the real one and then slide it over into position over top of the other. I just tried it in X10 and did not need to change the height. They may have improved that. Yes in X9 one must be elevated but not in X10 Link to comment Share on other sites More sharing options...
Aamir77 Posted July 17, 2018 Author Share Posted July 17, 2018 I have removed the casing for exterior door and voila, my 3rd difficulty resolved. Link to comment Share on other sites More sharing options...
