EconBlueprints Posted July 1, 2018 Share Posted July 1, 2018 How do you go about creating a porch with roof above where: 1. Porch Support walls are frost walls. Frost wall height is 42", frost wall is 8" thick. Footings are 10' x 20" 2. Porch walking surface is a concrete slab, 4" thick, and overhangs frost walls by 3" on three sides (abutts up to building on 4th side) 3. Top of slab is 5" below first floor sub floor (so top of frost walls supporting slab should be 9" below first floor sub floor) I tried by drawing the porch area with regular foundation walls, adjusted the heights, but I cannot get the slab to on top of the frost walls and overhang them by 3". Thanks in advance. Lane Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 1, 2018 Share Posted July 1, 2018 I think what Eric did is to draw a custom slab and place it on the stem walls, at least that is what his image looks like to me. DJP Link to comment Share on other sites More sharing options...
CharlesVolz Posted July 1, 2018 Share Posted July 1, 2018 If no foundation or frost walls are required, you can use a stair with one tread and the riser height, tread overhang and tread thickness set as desired. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted January 3 Share Posted January 3 On 7/1/2018 at 1:20 PM, DavidJPotter said: I think what Eric did is to draw a custom slab and place it on the stem walls, at least that is what his image looks like to me. DJP Please support the request below to update the porch floor... Link to comment Share on other sites More sharing options...
SNestor Posted January 3 Share Posted January 3 I’ve got a number of porch videos on my YouTube channel. 1 Link to comment Share on other sites More sharing options...
