dwelldesign Posted June 11, 2018 Share Posted June 11, 2018 This has happened few times now on both my desktop and laptop when starting chief and opening up a file. It runs through this Searching for file and scans through a tonne of directories. It has been about 1.5hrs and still hasn't completed. Has anyone else run into this or know how to avoid having it happen? Thanks so much for any insight. Chief Architect X10 Premier. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 11, 2018 Share Posted June 11, 2018 I have never experienced this kind of lag on my Desktop or laptop. Where I you, I would contact Tech Support to help you sort out what is wrong with your PC or Mac. DJP Link to comment Share on other sites More sharing options...
Chopsaw Posted June 11, 2018 Share Posted June 11, 2018 Did you delete or move any of the files it is searching for ? Still should not hang but that might explain the conflict. Tech support should be able to give you the correct advice. Link to comment Share on other sites More sharing options...
dwelldesign Posted June 11, 2018 Author Share Posted June 11, 2018 Thanks for the feedback guys - no the files have not moved and I haven't changed any of my file/server structure in well over a year. So it is a tricky one. I get tech support on it and post back the outcome. Link to comment Share on other sites More sharing options...
cjanderson66 Posted June 20, 2018 Share Posted June 20, 2018 @dwelldesign I too am dealing with the Lag on my Desktop. I am making small changes like editing text and I find the little circle spinning for up to 30 sec for it to make the edit at times. This has only happened just recently after the latest update and I am not sure what is going on as it is very frustrating. Link to comment Share on other sites More sharing options...
rlackore Posted June 21, 2018 Share Posted June 21, 2018 This is an issue we've run into at my office twice after the latest Chief update. I sent the problem into Tech Support, so they are aware of it. The problem is that Chief is looking for a network path or share location, eg: \\server\partition\chief\files The solution is to map the network or share drive to a local drive, eg: E:\chief\files ...and then go into Preferences>General>Folders>My Data Folder and Browse to the newly mapped local location. Link to comment Share on other sites More sharing options...
