Designer100 Posted June 7, 2018 Share Posted June 7, 2018 I would appreciate any help on this small remodleing of veranda addition. Attached is picture of existing. I am trying to added roof in midde. most of house is 7,3:12 pitch. But they have a min. of 4:12 pitch. (but the roof they have in there now on paito as you see in pics is less than that!) tying to keep windows. I cannot get it to work out. Newell Pergola - Aspley Creek Ln.plan 1 Link to comment Share on other sites More sharing options...
glennw Posted June 8, 2018 Share Posted June 8, 2018 Newell, You will have a very hard time roofing that as you want. If it were mine, I would leave the existing roof as is and use a flat, waterproof, operable roof something like this: You get a waterproof roof that you can open on sunny days - particularly suitable in a case such as yours where the verandah is so deep that it will reduce the amount of light reaching the living room doors. It would probably cost less than changing the existing roof. It would also be a great feature of the verandah and add some interest. http://www.vergolansw.com.au 1 Link to comment Share on other sites More sharing options...
Designer100 Posted June 8, 2018 Author Share Posted June 8, 2018 This is exising home Veranda. Just adding a new roof. and new slab , contractor has already given price. I design up addition on a 11x17 sheet. Link to comment Share on other sites More sharing options...
glennw Posted June 8, 2018 Share Posted June 8, 2018 How can the builder already give a price when firstly, you can't draw it, and secondly, you can't build it? Probably you should ask the builder what he priced! 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted June 9, 2018 Share Posted June 9, 2018 On 6/7/2018 at 1:38 PM, Designer100 said: I would appreciate any help on this small remodleing of veranda addition. Attached is picture of existing. I am trying to added roof in midde. most of house is 7,3:12 pitch. But they have a min. of 4:12 pitch. (but the roof they have in there now on paito as you see in pics is less than that!) tying to keep windows. I cannot get it to work out. Newell Hi Newell , looking at the Photos I don't think your floor plan is 100% accurate , my (rough) guess it the Curved wall radius is about 12' as there is a straight section either side of the curve both in the existing Verandah and in the upper Window curved wall where there is also a bump out on the left of about 16" ? The easiest way is to let CA auto build the House roof without any roof over the existing verandah and then turn off Auto Build and draw your own Roof plane in from the New Verandah Wall (beam) , it looks like 2.5 deg. works if you want to keep the upper windows using your plan foot print , which would mean you'd need Flat granulated Roofing Materials not Shingles on it. playing with the Depth and or height of the new Verandah may get you back to 3 deg. the minimum for most shingles. Aspley Creek Roof_MHD.plan Link to comment Share on other sites More sharing options...
glennw Posted June 9, 2018 Share Posted June 9, 2018 Mick, I understood that the minimum pitch allowed was 4:12. Although the first post wasn't very clear as I don't know who "they" are. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted June 9, 2018 Share Posted June 9, 2018 Hi Glenn , I didn't understand the 4:12 pitch comment either ( HOA ,City,Owner?), but at 4:12 you would lose the Windows , so I just tried what I thought would work, doing a Cross Section through the Verandah / Windows may help too , but an accurate As-Built would be a must , and the Drawings are different from the Photos. If the Windows were changed out to 12"-16" high versions to still allow light / Air flow 4 :12 will work by the look of it.... see green CAD Line below M. Link to comment Share on other sites More sharing options...
Designer100 Posted June 18, 2018 Author Share Posted June 18, 2018 Thanks for help. This is exist. house and just extending out porch. All windows are existing. Link to comment Share on other sites More sharing options...
Designer100 Posted June 18, 2018 Author Share Posted June 18, 2018 I worked it out okay. See attached. Lane.Joe Asprey Creek Ln.Sugarlwan 06.18.2018pdf.pdf Link to comment Share on other sites More sharing options...
glennw Posted June 19, 2018 Share Posted June 19, 2018 Newell, You are braver man than I. Glenn Link to comment Share on other sites More sharing options...
Rpadge Posted June 19, 2018 Share Posted June 19, 2018 Looks good Newell, I think you left an "S" out in perspective though Link to comment Share on other sites More sharing options...
