Is there a specific catalog where I can find a wall mounted pergola?  I found one free catalog option but they are limited, free standing and there are no wall mounted options.
Any recommendations or leads are appreciated.
Picture attached
5 hours ago, Chief16Designer said:
Or go to 2nd floor build a deck and change the materials to whatever you want just an idea
That's how I do all my patio covers, very fast for standard patio covers.
    32647
    pewufilo
    pewufilo
  • Similar Content
    • By DRyeHD
      I'm having a problem getting a deck to remain when I try to contain it under a roof.  The function of the roofs to the covered deck are to make a covered walkway to the covered deck.  I didn't know where to begin searching for this issue so I'm posting this.
      The attached screenshot shows where I'm able to get the roof and deck to look right (4'-1") and where the deck room conflicts with the roof (4'-0").  Ideally, I would make these both 4'-0".  When I try to adjust the deck rail in or out from the back of the house (shown at 4'-0") the deck disappears.
      I have attached the .pln file.  Any advise is appreciated.
      Ingram2.zip
    • By Meltdown00
      Is it possible to model this in CA? (Reasonably close.) How would I do it?
    • By TimelessJohn
      Hi All,
      "Roof Beams Appear as Solid Timbers not I-Beams as Preferred."
      I have a small insignificant detail problem that I wish to resolve and wonder if anyone has a Tip or Trick to fixing the fact that my Steel I Beams show up perfectly in my Posts and Deck patio beams but not in my roof beams.
      I have changed all of my defaults to I Beams in my settings to no avail, just curious if this a detail I will have to learn to live with or a glitch in Chief?
      Also I would like my I beams to show in the interior walls and imagine in order for this to happen I will need to create a niche and paint it black steel? Correct?
      Please see attached image.
      Thank you in advance,
      John
      Modders ADU Plan V3.plan
    • By TimelessJohn
      Hi All,
      John
      Steel I Beam Issue.pdf
    • By davebrett
      I am very new to Home Design Suite Pro and could use some help. I have looked for video's but all don't quite get me there.
      I am trying to build a free standing peaked roof pergola.
      I would like it 10' x 10 ' square with 8" posts and a 12" support post under the peak of the roof (so not very sloped).  I have attached a picture of what I am trying to make.
      I have tried making railings, walls and slabs, but I keep missing something.
      Help please
