How to display rough openings at window label?
Member Statistics
Similar Content
By Allen43
I have returned to this forum once again in seek some help with ruby and macros.
I have been working on a macro to automate cabinet labels. So far I have a mostly working macro, but I feel like my hands are tied and my eyes are closed. First of all the documentation on chief implementation of ruby and its capabilities it really lacking. And second, I don't have the Ruby terminal. I think this is because I am running Interiors, but am not sure as all Chief says is that there is limited use of Ruby in this version.
Anyways, right now I would love to have a list of all callable object attributes. I honestly don't even know if that is the right name for what I am looking for. I am trying to find a list of what info I can scrape from a cabinet. So, what can I put after obj. (ie. obj.width, obj.type)? I think I could find this by running the selected.names command in the terminal, but I have no way of knowing.
This is my current macro. It is built from parts of a macro from @MarkMc and whatever I have been able to come up with from random trial and error. If you see something I could improve on, I am open to suggestions as long as they have a good explanation with them. Thanks in advance!
Macro:
obj = owner
obj = referenced unless referenced.nil?
obj.depth
type = obj.type.to_s
nf = NumberFormatter.new
nf.unit = 'in'
nf.use_fractions = true
nf.show_unit = false
nf.apply(obj.depth)
standard_size = 24.0 if type == 'base_cabinet'
standard_size = 12.0 if type == 'wall_cabinet'
standard_size = 24.0 if type == 'full_height_cabinet'
depth = nf.apply(obj.depth) if obj.depth.to_f != standard_size
standard_size_height = 36 if type == 'base_cabinet'
standard_size_height = 0.0 if type == 'full_height_cabinet'
height = nf.apply(obj.height) if obj.height.to_f != standard_size_height
width = nf.apply(obj.width)
nomen = 'B' if type == 'base_cabinet'
nomen = 'W' if type == 'wall_cabinet'
nomen = 'T' if type == 'full_height_cabinet'
hinging = owner.door_swing
label = ""
label << nomen << width.to_s << height.to_s << depth.to_s << hinging
p label
By Allen43
I'll new to Chief and have learned that this form might be one of the best resources I have ever used. I am trying to streamline my design process and to do that I would love to be able to change cabinet ends to finished or paneled faster and easier. I tried to make a SP to do this, but I couldn't figure it out. I also thought that there might be a way to do this with macros is a SP, but I know even less about macros than I do Chief.
Any help is appreciated, and if it's not possible that's fine I'll know not to spend more time on this.
By Allen43
I am new to Chief but so far I love it. Far better than my previous software. So far, the only problem that I have had is using macros to create a custom label for cabinets.
All I am trying to do is get chief's labels to match my manufacture nomenclature. I know I could manually change it on every cabinet, but that seems like to much work and honestly a waste of time. So could someone give me some help. Either a bit of a guide on custom macros and some recourses and documentation (which I, for the life of myself, can't find), or maybe a working-ish or example macro.
Some examples:(chief nomenclature, needed nomenclature)
3DB24, B3D24
U242484L, T2484L
FHB24L, BF24L
Thanks in advance for the help! And if I didn't give enough information or if there is a better way to go about this, please let me know.
Oh, almost forgot. I am running Interiors x14.
By tlinder
I'm trying to run a .rb file that's on my local in CA by using a marco. Right now I can only get it to read the file. Does anyone have any insight on how I might be able to to this or where I need to look?
Macro: In CA
File.read("C:/Users - Desktop/scope1.rb")
Output: from text stored on a local drive
rafter_length = (length.to_f.round / 12) + 1
convert_to_int = rafter_length.even?
case
when convert_to_int == true
resut = rafter_length
when convert_to_int == false
result = rafter_length +1
end
By wazzubrad
Guys, I am starting to find some of the limitations that I see discussed in the forums and am wondering if this is one of those. The current plan I am working on has various footing widths and depths specified by the engineer for the foundation walls. While trying to create a wall schedule that will show each wall based on footing width and depth and when I look at the available macro's under Object Properties for a macro I don't see anything specific to the footing depth. Anyone know if this property exists for a foundation wall?
