gelbuilding Posted May 18, 2018 Share Posted May 18, 2018 Any way possible to view textures in plan view Link to comment Share on other sites More sharing options...
Chopsaw Posted May 18, 2018 Share Posted May 18, 2018 No I don't think so but I have seen some neat stuff done with an Orthographic top view if that is what you are getting at. Unless you wanted to do something really special and import image files into plan view. Link to comment Share on other sites More sharing options...
gelbuilding Posted May 18, 2018 Author Share Posted May 18, 2018 Thanks, Yes I know how to do in Orth view though it would be great in plan view See image attached, I place the pattern though would be great to add the texture. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 18, 2018 Share Posted May 18, 2018 For the flooring patterns ? I don't see why you could not bring in a properly scaled image and overlay it on there but not sure chief will make that an automatic option any time soon, but for the right presentation it would look pretty cool. Link to comment Share on other sites More sharing options...
rlackore Posted May 18, 2018 Share Posted May 18, 2018 George, please make this a request in the Suggestions forum - I would support it. Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 20, 2018 Share Posted May 20, 2018 I send top ortho view to layout as image and place it over the plan. The image will have to be scaled and then point to point place over your plan view. The image is even set to “back” by default so even that is already set up. Here’s an example. (Assuming I understood what you were looking for) Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 20, 2018 Share Posted May 20, 2018 ...need to make room fills as transparent. Whoops Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 21, 2018 Share Posted May 21, 2018 On 5/20/2018 at 7:58 AM, Michael_Gia said: The image will have to be scaled and then point to point place over your plan view. There is a much quicker way to do this actually. Just use Fill Window Building Only in both your plan view and in your orthographic overview. Then send each of the 2 views to layout as Current Screen. They will automatically be lined up perfectly. 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 21, 2018 Share Posted May 21, 2018 6 hours ago, Alaskan_Son said: There is a much quicker way to do this actually. Just use Fill Window Building Only in both your plan view and in your orthographic overview. Then send each of the 2 views to layout as Current Screen. They will automatically be lined up perfectly. This is a great tip except!....You can’t rotate the orthoview if it is sent as a plan view only if it is sent to layout as image for some reason. At least that has been my experience. Can’t rotate, not even with the “Transform/Replicate” tool. So this is why I send as image and resize since your tip about “fill building to window” doesn’t work unfortunately. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 22, 2018 Share Posted May 22, 2018 1 hour ago, Michael_Gia said: So this is why I send as image and resize since your tip about “fill building to window” doesn’t work unfortunately. Do this instead... Rotate your camera and Fill Window Building Only Send that view to layout As Current Screen Go back to plan view, click Tools>Plan Views>Rotate Plan View and rotate the plan view to orient it the same direction as you rotated the camera view. Fill Window Building Only Either send that plan view to layout As Current Screen, OR Click Tools>Plan Views>Rotate Plan View and rotate the plan view back to 0.0°, send it to layout As Current Screen, and then rotate the layout box. Again, these steps should automatically align your views. Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 22, 2018 Share Posted May 22, 2018 26 minutes ago, Alaskan_Son said: Do this instead... Rotate your camera and Fill Window Building Only Send that view to layout As Current Screen Go back to plan view, click Tools>Plan Views>Rotate Plan View and rotate the plan view to orient it the same direction as you rotated the camera view. Fill Window Building Only Either send that plan view to layout As Current Screen, OR Click Tools>Plan Views>Rotate Plan View and rotate the plan view back to 0.0°, send it to layout As Current Screen, and then rotate the layout box. Again, these steps should automatically align your views. Hey thanks! Worked like a charm. Now why didn't I think of that?... Link to comment Share on other sites More sharing options...
