boxerprod Posted May 6, 2018 Share Posted May 6, 2018 Hi Everybody , I have an open below space on the 2nd floor. I don't see how to do to put the edges of floor finish in white ? I'm sure is easy but couldn't find it. thks for your help Link to comment Share on other sites More sharing options...
boxerprod Posted May 6, 2018 Author Share Posted May 6, 2018 thank you for your lightning reply ..as usual. i'll try this Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 6, 2018 Share Posted May 6, 2018 Is your open below room using defaults? I don't ever have to patch that, it should be automatic for you. It seems to me that there is a setting wrong Link to comment Share on other sites More sharing options...
dshall Posted May 6, 2018 Share Posted May 6, 2018 1 hour ago, solver said: You cannot change just the edge. You will need to cover it with something -- a room molding polyline might work well. I have never needed to do this. Post the plan and Eric will probably give you a much better answer. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 6, 2018 Share Posted May 6, 2018 This is done with setting the railing to "Generate On Low Platform" and moving the Floor finish to the Floor Structure. Not really sure what is going on with the end wall unless that is a railing wall. Post your plan and someone will have a go and fix it. Link to comment Share on other sites More sharing options...
dshall Posted May 6, 2018 Share Posted May 6, 2018 22 minutes ago, Chopsaw said: This is done with setting the railing to "Generate On Low Platform" and moving the Floor finish to the Floor Structure. Not really sure what is going on with the end wall unless that is a railing wall. Post your plan and someone will have a go and fix it. I disagree with this answer also. If this was the case..... what defines the material at the edge? It is defined by the wall type finish. I wonder what wall type he is using. If this is the answer, I would be learning something new. I wish he would post the plan. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 6, 2018 Share Posted May 6, 2018 Scott, Here is the default wall type I think. Please clarify what it is you are disagreeing with. The edge material is the drywall that is defined by the wall type but it only seems to go up to the bottom of the floor finish layer or the top of the structure layer. Is there a better solution ? Link to comment Share on other sites More sharing options...
boxerprod Posted May 6, 2018 Author Share Posted May 6, 2018 Hi everybody. Here is the plan. The solution from chopsaw worked fine but maybe there is another way to do it that would leave the floor structure and floor finish as it is. Plan Maison v2018 -X10 - 017 - vers work.plan Link to comment Share on other sites More sharing options...
boxerprod Posted May 6, 2018 Author Share Posted May 6, 2018 3 hours ago, DRAWZILLA said: Is your open below room using defaults? I don't ever have to patch that, it should be automatic for you. It seems to me that there is a setting wrong Yes , i did not change anything on my side from what i remember. Link to comment Share on other sites More sharing options...
dshall Posted May 6, 2018 Share Posted May 6, 2018 3 hours ago, Chopsaw said: Scott, Here is the default wall type I think. Please clarify what it is you are disagreeing with. The edge material is the drywall that is defined by the wall type but it only seems to go up to the bottom of the floor finish layer or the top of the structure layer. Is there a better solution ? Im not at office to check. The wall type is correct but I have a feeling that is not the wall type he is using. Did you check it yet? Link to comment Share on other sites More sharing options...
dshall Posted May 6, 2018 Share Posted May 6, 2018 I will check in AM. Link to comment Share on other sites More sharing options...
dshall Posted May 6, 2018 Share Posted May 6, 2018 After looking at picture closer, I remember seeing this Anamoly a long time ago. I forgot the actual circumstance but maybe Chop’s is the solution I did not know of back then. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted May 6, 2018 Share Posted May 6, 2018 Scott, It looks to me like the French default railing wall. The interesting thing that it does do is wrap the floor finish over the underlay but unfortunately this is not the desired look this time. Link to comment Share on other sites More sharing options...
dshall Posted May 6, 2018 Share Posted May 6, 2018 4 minutes ago, Chopsaw said: Scott, It looks to me like the French default railing wall. There you go, that is what I thought it would be. Again, I am going off the picture and I swear, I have 1 pair of glasses and two types of contact lenses to choose from and I still can’t see too well. But if I choose the correct contact lens set, I can see my golf ball travel more than 175 yards. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 6, 2018 Share Posted May 6, 2018 Sink a few more balls and maybe when you get back to the office you will be all rested up and it will make sense. Link to comment Share on other sites More sharing options...
glennw Posted May 6, 2018 Share Posted May 6, 2018 The solid rail at the end is just a 3D Box drawn over a rail. The floor finish is going to the edge of the floor platform because the room is defined by rails, and that's what floor finishes do with rails. If you want the platform edge to come up to the top of the floor finish you need to delete the floor finish from Floor Finish and add it to Floor Structure. 1 Link to comment Share on other sites More sharing options...
boxerprod Posted May 7, 2018 Author Share Posted May 7, 2018 From what i understand, chopsaw's solution is the best way to solve this. Thank you all for your time and help Link to comment Share on other sites More sharing options...
dshall Posted May 7, 2018 Share Posted May 7, 2018 17 hours ago, solver said: You cannot change just the edge. You will need to cover it with something -- a room molding polyline might work well. I understand Eric's answer now. 1 Link to comment Share on other sites More sharing options...
dshall Posted May 7, 2018 Share Posted May 7, 2018 10 hours ago, glennw said: The solid rail at the end is just a 3D Box drawn over a rail. The floor finish is going to the edge of the floor platform because the room is defined by rails, and that's what floor finishes do with rails. If you want the platform edge to come up to the top of the floor finish you need to delete the floor finish from Floor Finish and add it to Floor Structure. Here is another option to deal with the edge at the half wall without using the box. You will alway see the edge of floor finish under the rail unless you take Eric's or dChop's suggestion. Plan Maison v2018 -X10 - 017 - vers work 66fpihi.plan 1 Link to comment Share on other sites More sharing options...
boxerprod Posted May 7, 2018 Author Share Posted May 7, 2018 1 hour ago, dshall said: Here is another option to deal with the edge at the half wall without using the box. You will alway see the edge of floor finish under the rail unless you take Eric's or dChop's suggestion. Plan Maison v2018 -X10 - 017 - vers work 66fpihi.plan Thank you , i didn't until yesterday i could do this with railing. Thanks for that. Link to comment Share on other sites More sharing options...
