Reference Items
SketchB
Turn on your Reference Display, select reference floor, select your desired reference layer set.  Save as a new Plan View and you can switch to it with a single click next time.
You can also toggle your reference display stuff using hotkeys and a macro recorder to make it a single click operation.  Don’t have time to go over that one though.
4 minutes ago, SketchB said:
That's not the issue I am referring to. What I want is, referencing other items, other than just the walls from floor 1 to floor 2.
Michael had your answer.  You just need to use a different "Reference Layer Set", one that includes the items you want to display.
Note that a "Saved Plan View" remembers the "Referenced Layer Set", including the referenced floor.
Ed Zachary, thank you.
To the OP,  These are the settings you need to familiarize yourself with...
