Designer1 Posted March 27, 2018 Share Posted March 27, 2018 I dont use bay windows much but I decided to use the Chief bay window tool. I wanted to delete the default windows in the bay and just copy and paste some other windows I have in the plan. When I did that it a message dbx came up and said you cannot place windows in a locked item. I searched around for how to unlock it but couldnt figure this out. Whats the magic key to allow for pasting windows into bays? Thanks! Link to comment Share on other sites More sharing options...
Kbird1 Posted March 27, 2018 Share Posted March 27, 2018 Box,Bay and Bows use the default Window , so you can perhaps change it there 1st if different from those used? you can also use TAB or the Next Icon to access the Windows in a box,bay or bow window too , to edit the in-place windows click over the window then hit TAB or the Next Icon and the selection should shift to the individual Window. M. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 27, 2018 Share Posted March 27, 2018 I build bay's and box outs manually, then you can do it any way you want. The auto system for those are just too limited. 2 Link to comment Share on other sites More sharing options...
dshall Posted March 27, 2018 Share Posted March 27, 2018 6 minutes ago, DRAWZILLA said: I build bay's and box outs manually, then you can do it any way you want. The auto system for those are just too limited. ditto 1 Link to comment Share on other sites More sharing options...
Ridge_Runner Posted March 27, 2018 Share Posted March 27, 2018 2 hours ago, DRAWZILLA said: I build bay's and box outs manually, then you can do it any way you want. The auto system for those are just too limited. ditto x2 Link to comment Share on other sites More sharing options...
Designer1 Posted March 29, 2018 Author Share Posted March 29, 2018 Thanks for all the input. Sounds like the bay, bow window tools are pretty pointless. I just liked how they easily can be moved around and changed. Sounds like some engineering on the tools might be a good idea to make these tools more popular. Link to comment Share on other sites More sharing options...
