RGWhite Posted August 7, 2014 Share Posted August 7, 2014 I need to make a sidewalk that has lots of curves and have the radius dim. I tried the sidewalk tool in terrain but it is limited. What is the best way you have found to make a complex side walk? Thanks Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted August 7, 2014 Share Posted August 7, 2014 Make it using a rectangular polyline in plan view and then convert it to a sidewalk. This way you can give it the exact shape you want. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 7, 2014 Share Posted August 7, 2014 You can also just use the Spline sidewalk tool. Link to comment Share on other sites More sharing options...
HumbleChief Posted August 7, 2014 Share Posted August 7, 2014 Only downside of the rec polyline is it won't follow terrain like a sidewalk will. Link to comment Share on other sites More sharing options...
jcaffee Posted August 7, 2014 Share Posted August 7, 2014 I use CAD arcs/lines, then convert to a Sidewalk centerline. jon Link to comment Share on other sites More sharing options...
RGWhite Posted August 8, 2014 Author Share Posted August 8, 2014 Thanks I will try all the suggestions. Link to comment Share on other sites More sharing options...
