Larry_Sweeney Posted March 3, 2018 Share Posted March 3, 2018 If I want to make a custom stained glass is there a certain technique to go about this. My thoughts are that I would open a new plan and make a pattern using a glass material. I would then give different pieces slightly different translucent colors to make my pattern. I would than add my leaded frame. These all would be made from p-solids. Once completed would I save it as a symbol or can I save it as a material? Is it possible to do what I'm trying to accomplish in CA and is this the correct way to go about it? Am I missing any important steps? Link to comment Share on other sites More sharing options...
Chopsaw Posted March 3, 2018 Share Posted March 3, 2018 Sounds like you are on the correct path. The only thing I might suggest is custom muntins for the lead rather than p-solids. Here is an old thread with a few basic examples. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 3, 2018 Share Posted March 3, 2018 Yes custom Muntins came to my mind reading above too...there is a KB Article about doing those : https://www.chiefarchitect.com/support/article/KB-00930/creating-custom-muntins.html Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 3, 2018 Share Posted March 3, 2018 I would personally do it completely from scratch and forget the muntins . Muntins are okay but are a bit limiting and less realistic than other equally quick options. Plus, you're going to need to create your separate glass pieces anyway. It's only a couple extra steps with boolean operations to model the lead caming. Link to comment Share on other sites More sharing options...
